uk bbc channels normally on 28.2 on intelsat 907 27.5w ?
StefanoFI
Channel Master 1.8
Inverto Black
Nokia 9600
Echostar LT 8700
Dreambox 7000
Dreambox 7020HD
Firenze, Italy
Just to know how much trouble is on my end and what may be caused by other factors: has the satellite signal weakened a bit lately, or should I try to check for grown leaves (already done, actually, but with no apparent improvement)?
Thank you in advance for any hint.
Stefano
Signal @ 14dB on my 88cm dish so no change here for last 12 months,
You may need to realign your dish.
nwaggy
1200 dish twin lnb full sky plus 907 to keep her happy
nerja costa del sol spain
nwaggy
Its fine here In the south of spain as good as ever
StefanoFI
Channel Master 1.8
Inverto Black
Nokia 9600
Echostar LT 8700
Dreambox 7000
Dreambox 7020HD
Firenze, Italy
Thank you. In some ways is good news. If it were the satellite, problems would be much bigger, and not only for me. I will try to check my equipment. Now I know it depends on me I can dare to get deeper.
StefanoFI
Channel Master 1.8
Inverto Black
Nokia 9600
Echostar LT 8700
Dreambox 7000
Dreambox 7020HD
Firenze, Italy
It turned out it was the cable. Already needing substitution since several years, it has always been a difficult task to carry out.
Its last bits of quality dropped sharply in few months, coinciding with tree leaves explosion and this added further doubts.
Now all is back, and of course not only 27W. All the Clarke belt was revived by the change.
I am now even getting at times glimpses of some UK beam channels @28E. Only SD, but still it feels like some fresh air breeze.
Stefano
BelGacem
dreambox 500s /2.4m dish
Tunisia
Hello,
Can I get this satellite in southern Tunisia with a 2.20 m dish and an inverto black ultra head with a feed horn ?
The fall off is rather sharp as the footprint moves south (and East) of the official chart.
Intelsat 907 at 27.5°W - LyngSat Maps
Northern Tunisia I would say yes, southern climes, something bigger.
BelGacem
Tunisia
Yes, thanks for the reply. The reception is confirmed in Northern Tunisia by a friend. Also, another friend in Gafsa ,not so far from my place,confirmed getting this satellite. So I m going to try soon I hope.
Make the most of it - 907 is coming up to End Of Life
trigger
Puerto del Carmen, Lanzarote
30W, 27.5W, 7W, 0.1W
4.8E, 9E, 13E, 19E, 23.5E, 26E, 28E
Technomate 5402HD super
Bein Sports on 25.5E
FTE Mini S2T HD Analyser
Horizon HD S2 sat meter
Lanzarote, Canary Islands
Maybe that end is closer than we think. Maybe its started wobbling as signal has dropped quite a bit here. I can see the transponder on the spectrum but no lock. Technomate box is flashing from 0db to 4.9 and off again.
radicaldoc
1.2 gilbertini with VU+ Solo2. 60cm with Spanish TDT from satellite.. and channel master 1.0m for 27.5 hopefully..LOL
Horizon USB Plus
Nr Martos, Jaen. Spain..
this happens regularly it will sort it's self out shortly.... Hopefully LOL
Just did all good now
Adam792
Cheltenham
Done a bit more investigation on this transponder in the last couple of days.
It turns out there is EPG data in there, it just doesn’t come up as it’s on a non-standard PID (the EIT data is on PID 58 which is also encrypted like the channels, rather than the standard DVB PID 18). It contains listings for all of the Freeview channels across all multiplexes (including the ones not replicated on 27.5°W) including the regional variations. There’s listings data for over 300 channels reported when I analyse that PID! This makes sense as each freeview multiplex on terrestrial carries all the EPG data for all channels so the guide populates quickly.
Also, the “Fat CSI” service includes bouquet data for all of the different Freeview network IDs - e.g “South Lakes”, “West Midlands - Birmingham” etc.
joejack
Archived Member
Only Sky atm
France
Struggling to find a working footprint map for 27.5W - anyone happen to know if an 80cm dish would be enough in Mallorca?
Nalleman
Motala Sweden
Sweden
StefanoFI
Channel Master 1.8
Inverto Black
Nokia 9600
Echostar LT 8700
Dreambox 7000
Dreambox 7020HD
Firenze, Italy
What is happening on this link today?
Everything was nominal until yesterday evening.
Several reports across the web.
Anyone knows if it is just a glitch or something that will last?
Thank you!
pipino
Back from the dead
2X Channel Master 1.20 , 1X Channel Master1.80 ,1X Channel Master 2.40, Motorized Gibertini OP150 , Motorized Fibo MF90 ,, 70cm eliptical raven ..hirschmann fibre glass 1.20m
Comunidad Valenciana..ESPAÑA
signal back again !
StefanoFI
Channel Master 1.8
Inverto Black
Nokia 9600
Echostar LT 8700
Dreambox 7000
Dreambox 7020HD
Firenze, Italy
trigger
In the canaries we have seen on 3 occasions recently that signal has dropped by around 2db and then back up again the day after. Interesting that no other reports have appeared on here. Strange
Beli1910
Sevnica-Slovenija
Wave frontier t90 45E-5W
Triax 110-,motor
Laminas 1.8m and Laminas 120
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Sevnica 8290-Slovenija
For the last couple of days, I have noticed a big change and a drop in the signal by approximately 4db from my location. For the vast majority of hobbyists from my area, this satellite will be basically inaccessible if it stays like this.
