UK football 15W
saj1985
Dreambox 800HD SE, Dreambox 500S, Skybox F5S, 90cm Solid Dish, Tm2600 Motor, Inverto Black Ultra LNB! :)
Lost...
Everton v Chelsea is on now too on
15w - 11518 H 3743 Tagged as DAD-4 (NTSC)
15w - 11527 H 3197 Tagged as DAD-5 (PAL)
its NBC coverage with english commentary! :)
remlap
Wales
Neither are PAL or NTSC, both are 480i
saj1985
Lost...
remlap
Wales
my bad, sorry :)
Don't rely on these feeds though for football just last week the DAD-5 transponder was an empty carrier.
saj1985
Lost...
i hear what your saying mate, i've noticed that nfl comes on this feed too
Hixxy1
East Midlands
480i is just the resolution. It can be either PAL or NTSC. It's normally associated with NTSC whereas 576i is mainly associated with PAL.
The i means its interlaced scanning, displaying the different fields (odd lines for 1 second and then the even for another and vice versa).
PAL & NTSC is how the colour information is encoded.
480i = 640x480 interlaced scan
576i = 720x576 interlaced scan
remlap
Wales
Think about it mate NTSC and PAL are analogue.
Retired human
Those with 480i though are likely to have 30fps frame rate. Can appear jerky on some TBs.
Sent from my HTC One X using Tapatalk 4
Hixxy1
East Midlands
Yes that's often the case Captain. Switching from 50hz to 60hz on the receiver often helps.
NTSC & PAL can be either analogue or digital remlap but I see where you're coming from.
remlap
Wales
No sorry mate, DVB is either digital video with 25fps or video with 29.97fps whatever the resolution.
Actually I've seen broadcasts at half frame rate and double 15fps and 50/60fps.
Hixxy1
East Midlands
Apologies. I must be getting confused, it's probably due to messing around with old mpeg encoders and getting my wires crossed :)
remlap
Wales
Analogue in Digital out mate I expect. ;)
