- May 26, 2020
- Raven mk2 zone 2 x4, Channel Master: 90cm x3, 1.2m x2, 1.8m PF. CM polar mount x2, Az/El x3.
- South Durham
You won't find a consumer hobby receiver that is fully compatible with this LNB. It's a professional grade LNB designed for professional systems. These are your options with the Technomate:
SMW LNB, frequencies correct, polarisation as per position name:
With SMW set as Universal, frequencies incorrect, polarisation as per position name:
With a universal LNB, all frequencies correct, all polarisations correct, auto polarisation:
Your meter is probably finding exactly the same as the Technomate set to universal settings.
Technomate position name | LNB settings, all single | ASC1 |
1. 4.8e 10.7-11.7H | 18v, 22khz on, LO 9.750 | 4.8e H |
2. 4.8e 11.7-12.25H | 13v, 22kz on, LO 10750 | 4.8e H |
3. 4.8e 12.25-12.75H | 18v, 22khz off, LO 11300 | 4.8e H |
4. 4.8e 10.7-11.7V | 18v, 22khz on, LO 9.750 | 4.8e V |
5. 4.8e 11.7-12.25V | 13v, 22kz on, LO 10750 | 4.8e V |
6. 4.8e 12.25-12.75V | 18v, 22khz off, LO 11300 | 4.8e V |
Technomate position | LNB settings | ASC1 |
1. 4.8e Ku H | Universal | 4.8e H |
2. 4.8e Ku V | Universal | 4.8e V |
Technomate position name | LNB settings | ASC1 |
1. 4.8e Ku | Universal | 4.8e auto polarisation |
