Using the Premiere card work outside of Germany?
sashi002
I have Hotbird, Arabsat and Nilesat
UAE, Dubai
what about watching those german channels outside of germany? does the premiere card work there?
The premiere card will work anywhere inside the coverage area with an appropriate receiver. The UAE is probably too far east to get coverage though.
Yes if you can a) receive the satellite (have a big enough dish) and b) get hold of a card.
4dbennett
lifes not a practice run
SPIDERBOX 9000HD, 1.2 and Humax Foxsat HD,Hitachi L500HDD
Acer Aspire 5315 Lappy
torfaen south wales
You invited this question Rolfy!!
How doe,s one get a card and any idea how much it costs
regards Dave
HB13DISH
Retired Mod
Middle East - Israel
What is your dish size?
I believe that many of the Sky Germany channels can be received with a relatively not so big dish (1.2-1.6m) in the UAE.
Check the channels under the Wide beam from 1M.
Why don't you point your dish (whatever size it is) to Astra 19.2E and see which channels you can see after scanning?
You can then worry about how to get a subscription card.
_http://www.lyngsat.com/astra1m.html
_http://www.lyngsat.com/packages/skydeutschland.html
Report back if you can, as this can help others living in the ME.:)
T_G
The Consumate Dreamer
1 GigaBlue Quad plus, 1 Dreambox 5620, MOTECK SG2100A DISEqC Motor, 120 cm noname offset dish, Humax 95 cm offset dish and a few UK digiboxes.
Somewhere where the Sauer is Kraut and the Wurst is Brat
Why would you want to get the sky Germany? If you are after German programs, then there are a dungload of FTA channels available. Their movie channels are showing the same movies as all the other major packages, the mature content is the same (well all mature content is the same anyway :) so the only thing they got is the German football...
Turok
1,25 Fibostop
Jäger Smr 1224 & Smo 36 Dual Axsis Motor
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Tagra 2,20 M Fullsize Dish
Echostar 2,40m Mesh for cband!
Austria
Hello!
where are you located?
when you are from dubai,like i read in your profile,then i dont think that is posible to reive the sky germany channels?
the signal is stronger,since the change of the satellite,in greece and other areas,but not in dubai!
HB13DISH
Retired Mod
Turok said:
Hello!
Turok,
Take a look at the Wide beam footprint from Lyngsat.
It should be possible to receive some channels, even in the UAE.
_http://www.lyngsat-maps.com/maps/astra1m_wide.html
BombedOne
Republic of Georgia
Wide beam channels are OK in dubai - discussed and confirmed already many many times in relevant 1M topic...
sashi002
UAE, Dubai
but i have like scrambles channels shouldnt they work with a card?
sashi002
UAE, Dubai
i dont know the size of the sat as every building here has a common one unless i do apply a provite one but am not sure if i can find astra here!
sashi002
UAE, Dubai
i will try that thanks
MarcusDubai
Dm8000
Dubai - UAE
once and for all:
ASTRA 19,2e 1M-WIDEBEAM DOES WORK IN DUBAI with 100cm offset dish and up! not a problem!!!! even a stronger signal than 13e Hotbird!!!!
and for all other germanspeakers: 09e --- KABELKIOSK will give you full german tv with 165-185 PFA dish-----
and yes - you will be able to find ORIGINAL SMARTCARDS for that in Dubai......
greetings from the sunny side of dubai!!!
