VU-Zero Help pass/login
mikedelta25
hispasat
Portugal
Good afternoons
I have a new line only that I can't get to it because the previous server changed me to pass and login
From the box, I have no access to the VU + CC, DreamEdit or Dreamset, via (telnet-Ftp-Network-crosseover-router
And so on.
How do I recover the pass???
Thank you
The best (probably only) way is to reflash the box with a clean image.
We do not help with card share issues on this forum - we always advise use of legitimate subscriptions to the pay services you require.
mikedelta25
hispasat
Portugal
That's what I didn't want to do, put in new image, as for the
The rest was unintentional I asked the question, but thanks in the same
Mickha
North West
Check your receivers IP Address, and try the DCC, Dreambox Control Centre, as this will find all devices, connected to your network.
There usually isn't a password, it's left blank, the username is root.
sonic1
Vu + Ultimo 4K - Solo 4K - Uno 4K - Duo2- SoloSE - Zero- Uno -Prismcube Open Black Hole - 0.6 , 98cm Funkee , 28E-23.5E-19E-13E
Black Hole Team
The user and pass has been set by the previous provider to leave you with no control of your box, unless you are an extremely good hacker then a re-flash is the only way to take back control of your box as stated by Analoguesat
