What is the best twin cable for a motorised dish?
skomedal
This and that
thule
I can't see where the Smedz cable is manufactured though (nor results of testing)
Don`t shoot the messenger :D
Someone asked for a link, thus link provided :-rofl2
Rest my case!
Loquacious
Shoreham by Sea - West Sussex - UK
Motor : HD Line DisceqC Motor 50-120 ( apparently a Moteck SG2100A clone)
Dish : Dur- Line Aluminium 75/80cm
LNB : Dur - Line Twin
4. Receiver: Fortec Star HD Passion Plus ( 2010 )
5. WF 100 cable
Shoreham by Sea
Never heard of them.
There was a thread on here about suspect cables that once stripped were found to be made of recycled materials, including toothpaste tubing and chewing gum wrappers.
Make sure you have a company address and a returns policy in writing before ordering/paying anything
Thanks, I will by the WEbro WF100.
I
Loquacious
5. WF 100 cable
Shoreham by Sea
AT LAST - he "understands"! :D
OTOH: it could be cheaper from CPC Farnell
Loquacious
5. WF 100 cable
Shoreham by Sea
How the connectors ? Is there something that you can suggest as well?:)
I think we covered connectors in the other thread that you started!
Loquacious
5. WF 100 cable
Shoreham by Sea
Could give me a model? I am about to order altogether from CPC Farnell.
Here is some info (hope I've covered most things!)
Instructions on how to fit an F-plug
How to fit F Connectors to coaxial cable for Sky and Freesat
You will need:
F-connectors – general
http://cpc.farnell.com/search?st=f%20connector
You need ones for 6.8-7mm outside diameter cable (WF/CT100 is 6.8mm)
And I suggest these: F-connector with O-ring but there are numerous others on that site, ebay, etc.,:
http://cpc.farnell.com/vision/fm02/plug-f-twist-on-rg6-100/dp/CN20704
NB: suggest you order twice as many as you think you will need!
Cable stripping tools – various dedicated coax cable strippers:
http://cpc.farnell.com/search?st=coaxial%20cable%20stripper
OTOH, I use one of these (and it’s very handy for lots of other jobs):
Stanley Folding Pocket Knife 0 10 598
https://www.amazon.co.uk/Stanley-Folding-Pocket-Knife-598/dp/B0001IWDBU/ref=pd_bxgy_60_img_2?_encoding=UTF8&psc=1&refRID=KG339X8VT1SAV697G7BN
Spare straight blades for the above:
https://www.amazon.co.uk/dp/B0001IW5FO/ref=pe_385721_147587461_TE_dp_1
Pair of sharp side-cutters with blades that have no gaps between them when they close – you may already have these, but they are widely available
A tool to tighten the F-connectors onto the LNB, etc.
I use pliars and a modified open-ended spanner, but the F-connector is a rather unusual size, so here are some dedicated tools:
http://cpc.farnell.com/unbranded/33-3085/driver-f-connector/dp/TL04780?ost=f-connector+spanner&iscrfnonsku=false&ddkey=http%3Aen-CPC%2FCPC_United_Kingdom%2Fsearch
https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2054502.m570.l1313.TR1.TRC0.A0.H0.Xf-connector+spanner.TRS0&_nkw=f-connector+spanner&_sacat=0
Self amalgamating tape - widely available from ebay/amazon/your local DIY place, but here is some on the CPC site
http://cpc.farnell.com/search?st=self%20amalgamating%20tape
Loquacious
5. WF 100 cable
Shoreham by Sea
You will need:
Thanks again! I will update you when the job is underway. Cheers:-applause
DOB010101
Dual LNB to receiver, and RF modulator to 4 televisions
Denmark
You can find a very wide selection of cables here.
In my experience, buying them too cheap is a very bad idea. Go for quality, it will pay off in the long run.
The thread is about a year and a half old so I would hope that Loquacious is sorted by now!
Since his final comment in the other thread about how to actually set up a motorised dish at around the same time he started this one, we haven't heard anything at all from him - he came, asked questions and then "disappeared".
Sadly we quite often don't hear about the final installation. It's really nice when someone asks for advice and then finishes the thread by saying that everything worked. Or at least finishes the thread!
Terryl
Custom built PC
Hey, I running backwards in time, so I might come across this post as it happens, I can find out then.
