X2 Premium HD
Archived-1
Persona non grata
uk
Hi Martin that sounds interesting does it have an accurate Blind Scan ?
Which model is the best DVB S2 - X SQUARE TECHNOLOGY
@william-1 . Hi Will, its this model I use, it can be a little bit out on weak signals but the blind scan is very quick, I put it side by side with the tm 6900 blind scan model and it finds everything that does and the tuner is better on weak signals, this is an older model, @Costactc would be best to advise you on the later models :)
Thanks for this :)
Archived-1
Persona non grata
uk
Hi Will ive just done a video scanning at 4W they will be some 5W scanned in as well, just over 3 minutes, screen grabs of tp found. sorry about the video quality and TOTP in the back ground lol.
The Menu's on the X2 Premium are very similar to the Spiderbox 6000HD that I tested over 2 years ago,
Most of the comparisons made here with the TM5302HD are very interesting,
It is a bit like comparing the DrHD D15-F15-F16 series with the TM M1-M2-M3 series basically they are the same receiver with some minor changes.
Tuner sensitivity can be influenced by changes in software the original software when altered to accommodate new features,
Software updates can also effect other normal receiver functions such as DiSEqC motor controls & Blind Scan functions ect if done by persons not fully conversant with what all the original software does & can degrade the normal receiver functions,
I am looking forward to the next satellite receiver that I test the software writer has got it right 1st time :)
Archived-1
Persona non grata
uk
the tm5402 hd mk3 I think they are a good receiver with a good tuner and fast blindscan !!!
to be honest a lot of members on here have them also !!
Hi Steve, would you do a blind scan with the 5402 at 4W and time the scan pal please.
X2
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
Will that be the new Technomate then?
parkiepie420
technomate tm-5402hd m3 /gibertini 1.25m sat dish 51e to 34w inverto black ultra single 0.2db lnb / titanium single output cband lnb
technomate tm-5402hd m3/triax 1.1m dish 53e to 24w inverto black ultra single 0.2 lnb
sheffield south yorkshire uk
hi martin will do and I will post results asap !!
