55.5w
So that Jamaican mux doesn't exist any more?
Hi -
I managed to lock the Jamaican mux a few times for a short period of time ... over 3 years back now ... not tried for a long while now .. but like you, had no signal at all ... away from home on hols right now .. will have a try when i get home .... cheers .
Bring us a stick of rock back :)
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Not seen it for years Alex ..
either went onto a very tight low power beam ...or simply closed the service..
Sadly,,
Anonymous_1
@Feedsat, you have a very nice low noise floor looking at your trace, i'm envious :)
don't be envious John, unfortunately, I have just an old Promax TV Explorer II+ and 55.5°W is only available on my small 1.80m for the moment...
you can have the same spectrum, by following this very useful link (but unknown for most of the people til now ;) ):
Satellite Signatures - Real-time Satellite Spectrum Plots
Thank you kind Sir
nelson_b
Contributor
nelson_b
Contributor
WHATAGOAL1
2.4, 1.8channelmaster, tm5402, tech1500, db920
Leic
just had good scan, but missing sportsmax, has it disapeared?
Anonymous_1
Sportswmax mux is now available in HD (SR 1000) but all enc, the SD signal on 4067 V has left
WHATAGOAL1
Leic
used to get it easily, now 55w is getting the most channels i have ever, and no sign
wonder if because of low symbol rate, has it changed from 8000?
nelson_b
Contributor
This morning's scan. 4003V also comes in OK at 8dB but wasn't picked up by BS for some reason.
Anonymous_1
COPA Active test
3971 H 7500 3/4 COPA TC
3984 H 14400 3/4 WORLD FEED (ENC)
aceb
Prof Tuner 7301 /
Sussex
3975V, 2500, 34, 8PSK. IDing as Maronas but relaying Canal U - Vera TV Uruguay.
aceb
Prof Tuner 7301 /
Sussex
3916V, 14999, 34, S2-QPSK IDing as NT Live. Intro by Kirsty Wark into Saint Joan, live from The National Theatre, London. This is being screened at various cinema around the UK and presumably further afield.
aceb
Prof Tuner 7301 /
Sussex
I'm assuming this is a feed although Lyngsat has no feeds listed in this part of the band.
3750H, 1666, 34, 8PSK. IDing as Rpp Fly 01 Speech by OM, Peruvian Interior Ministry?
