Intelsat 904 (45E)
Two frequencies are reported to have moved off Intelsat 12 onto 904. Massive signals here on both
11635V 30000 3/4 DVB-S2 8PSK 16.3dB
11675V 30000 3/4 DVB-S2 8PSK 15.5dB
MCelliotG
Thessaloniki, Greece
Massive signals here as well (as expected). The signal is virtually the same as Intelsat 12's.
popovp
My system:Receiver-Ferguson Ariva 102E HD, Sky Sat 9900FTA+emu;Ferguson FX-6600CR/OCTAGON SF318 soft;LNB-Sky Sat, universal, 0,2dB;1.17x1.06m offset dish ;Diseqc 1,2 +USALS Moteck2100A motor; 1,2m parabola+0,3dB Inverto @ H-H Strong SRT DM 2100
Varna, Bulgaria
Dish size?
tempo
47.5N, 42.2E / Russia
Last night all remaining transponders in the range 11450V-11700V were switched to Intelsat-904
All signals are weak for me now, below the lock treshold :(
Also seems 11595V has changed SR for full TP bandwidth usage
This is the situation here.
I think the hump at 12650 V appeared recently.
Intelsat 12 transponder 12650 V has uplink at 14391 V.
And that is very close to the Intelsat 904 uplink 14395 H for the 11595 V downlink.
New frequencies & symbol rates for Intelsat 904
11513 V 30000 S2 8PSK 2/3 NURTS Bulgaria (previously on 11509)
11555 V 30000 S2 8PSK 3/4 Vivacom (New channel line up)
11595 V 30000 S2 8PSK 3/4 Vivacom (previously on 11550)
11635 V 30000 S2 8PSK 3/4 Vivacom City tv fta
11675 V 30000 S2 8PSK 3/4 Vivacom (No change)
On 11488 V 10500 is the BNT package of NURTS (with PLS).
Laser
Prima TV and Kiss still to move I guess Ex Intel 12 from 12559V 5787 ?
+ Dialog TV has 6 transponders for India on Intelsat-12 yet to move to Intelsat 904,
I do not see a spot beam for South Africa on Intelsat 904 so Telly Track so may leave this satellite,
Telly Track South Africa on is available from these satellites:-
54.9°E Yamal 402
4.8°E Astra 4A
54.9°E Yamal 402
4.8°E Astra 4A
Galaxy-11 however, also at 45.0°E, does have a beam for South Africa!
Conversely Intelsat-904 can replace the 4 AOL transmissions on Galaxy-11 as it is reaching the end of use in geostationary orbit.
Galaxy 11 was the first BSS-702 satellite. It was ordered in May 1997 and was successfully launched in December 1999 on an Ariane 4 rocket from Kourou, French Guiana. Galaxy XI has a payload of 64 active transponders; 24 operate in C-band and 40 operate in Ku-band. The spacecraft was designed for an end-of-life power of more than 10 kW for 15 years.
The satellite used to provide service to North America and Brazil.
Galaxy 11 suffers from a generic failure of the early BSS-702 model: the fogging of the concentric mirrors on the solar arrays leads to reduced available power.
All three satellites at 45°E are rather old!
Launch date & estimated end of service life, as of Dec 31 2016:
Intelsat 12 (Oct-00): Q4 2017
Galaxy 11 (Dec-99): Q4 2018
Intelsat 904 (Feb-02): Q2 2019
See Form 20-F (Annual filing), pdf page 42: SEC Filings | Intelsat
@tempo you have PM.
I wonder if AzerSpace 2/Intelsat 38 45° East launch sometime in 2017 will be able to replace all current satellite transponder leases here ?
Arianespace Selected to Launch Azerspace-2/Intelsat 38 Satellite at 45 Degrees East -Arianespace
Expected to launch in 2017, Azerspace-2 will be Azercosmos’ second telecommunications
satellite, and will expand on the current capacity of Azerspace-1. It will support growing demand
for Direct-to-Home (DTH), government, and network services in Europe, Central and South
Asia, the Middle East and Sub-Saharan Africa.
MCelliotG
Massive signals on the newly passed frequencies again, up to 19.7db!!!
Parameters have changed: 11470 V 18333 DVB-S2 QPSK 3/5.
popovp
Varna, Bulgaria
What is the situation now - is it available this new transponder now? Can You scan again? Not fixed here in Bulgaria.
Sorry I'm not home this weekend, but elsewhere 11475 V 26660 is reported (tnx milan58). Note that PLS is used that most receiver can't handle (but probably you know)!
popovp
Varna, Bulgaria
Yes, I know. Somе friends will test with appropriate equipment.
P.S. They have tested and it's O.K. with SR 26660.
