Drake ESR 800XT
rancerote
IRTE 180cm Corotor Chaparral HHMotor, Drake SR 800XT, Nokia HDCI 2000, DB 800
PC Win7 Q6600 5Gb ram
Italy, Sulmona
Hello everyone
I restored this receiver to move my motorized dish but I haven't its manual, anyone could send it to me via PM ?? The function that can not be drawn is that the realign of the satellites through the receiver software, if someone who knows the procedure could help me I would be very grateful.
I thank everyone in advance for your time & help
Coviello
Potenza (Italy)
Prodelin 11ft (335 cm)
Windows 2000 XP
Southern Italy
Hello everyone
I have got Drake 2000xt, and its manual. If you are interested in, I will send you the *.pdf file.
Coviello
rancerote
Italy, Sulmona
Thank's a lot Coviello, waiting for your .pdf hope you a Happy New Year 2015 ... Immagino tu sia italiano quindi gli auguri sono ancora più sentiti, grazie per il tuo interessamento
Will Spanish be OK ?
  • Drake_esr-d800.pdf
rancerote
Italy, Sulmona
Thanks a lot for your pdf file, but my receiver refer to old ESR 800XT wich is not digital series but analogal. Thanks again for your time and interest
The operation of the positioner is unlikely to have changed.
rancerote
Italy, Sulmona
Ok, I'm going to get a look tomorrow and report, thanks again
pudapop
c/m dish, snf-031 lnb, TM-5402 HD M2 C1 super receiver
N I
Hello everyone
Hello everyone
Hi, everyone I'm new here and enjoying the discussions.
I have still got my ESR 800XT Plus 2 Satellite Receiver, If you can select a page(s) from the Manual that may help let me know
Hello everyone
I have still got my ESR 800XT Plus 2 Satellite Receiver, If you can select a page(s) from the Manual that may help let me know.
  • Drake.pdf
  • Drake.rear.pdf
rancerote
Italy, Sulmona
Hello pudapop,
thanks a lot for your interest about my question. The pdf files are great but the jpg doesn't let me read anything because is to little. Can you reply with another one more big ?? Or if possible for you, building a pdf file with all the manual will better. Thanks again and have good time
Also, take a picture of the rear of the receiver, in particular the positioner connections.
rancerote
Italy, Sulmona
Refer to me o to pudapop ?? In case, pudapop post a pdf file with the rear face of the Drake
pudapop
N I
  • Drake.rear.pdf
Document is blank.
pudapop
N I
rancerote
Italy, Sulmona
thanks a lot pudapop
fxdwg
Reelbox avantguard ii (Almost)
Drake ESR 2000 XT 10 YRS
cambridge
Hello everyone
This post reminded me off the Drake ESR 2000XT in have in wardrobe lol still, and yes it is 2017 and a response to a 2014 post but hey lol
BRCT203
multiple dishes ranging from 40cm to 120cm, plus a 10-foot Winegard Quadstar being refurbished. Visible arc: about 20W to 125W
Connecticut, USA
Hello all,
I am setting up a salvaged 3-meter Winegard C-band dish, and I have a Drake ESR 2000 XT + that a friend gave me recently. Obviously the receiver is obsolete as it's analogue-only, but I'm hoping I can use the positionner part. Unfortunately I don't have the manual - the closest I have are the scanned pages for the ESR800 that Pudapop posted above (Thanks!). But I'm a bit confused by the connections... I see only one connector for the actuator sensor (2-wire Reed sensor). Does the other wire go to GND?
Of course if by any chance someone could post a copy of the manual that would be fantastic
Thanks in advance for any guidance
Hello all,
Yes, ground. If it is anything like this link
https://www.satellites.co.uk/forums/attachments/drake-rear-pdf.72095/
then you have M1/M2 and depending on the actuator, then two or three wires for the pulse sensing piece of circuitry.
BRCT203
Connecticut, USA
Thanks Channel Hopper!
