Just Sharing This TM5402HD Ch list by William-1
My Festive TM5402HD Ch list by William-1 for Dec 8th 2016,
All transponders updated 53 east to 30 west,
You can also use this list for TM5402HD M1- M2 -M3 - F3/5 & TM6800HD Super,
Also other receivers that use the NDF file system such as ClarkeTech, Strong, DrHD ect,
This is a Motorised channel list for 53 east to 45 west you can also use this list for fixed dish set ups.
  • TM5402HD Ch List by William_1 for Dec 8th 2016.zip
TM5402HD Ch List by William-1 for 8th Feb 2017
Full update for 28.2 east,19.2 east & 13 east most other satellites are up to date.
90cm dish used for this update so only 9 transponders for Badr-4 @ 26 east.
You can use this list for TM5402HD M1- M2 -M3 - F3/5 & TM6800HD
  • TM5402HD Ch List by William_1 for 8th Feb 2017.zip
Update for 28th May 2017
TM5402HD Channel List by William-1
53 east to 45 west All transponders updated
New BBC Red Button service for Wimbledon added to 28.2 east
This channel list is suitable for all single tuner satellite receivers using the NDF file system,
TM5402HD M1, M2,M3 & TM6800HD
Blade 7000s, DrHD D15, DrHD F16, +Clarketech & Strong.
  • TM5402HD Channel List by William_1 for 28th May 2017.zip
Technomate TM5402HD Channel List by William-1
July 3rd 2017 all satellite transponders updated
Quest,Quest+1,Quest Red,Quest Red+1 Free to air on 28.2 east
BBC Red Button Ch 392 to 398 For Wimbledon Tennis
For more channels just re-scan any satellite.
This channel list is suitable for all single tuner satellite receivers using the NDF file system:-
TM5402HD M1,M2,M3 & TM6800HD
Blade 7000s, DrHD D15, DrHD F16, + Clarketech & Strong.
  • TM5402HD Channel List by William_1 for July 3rd 2017.zip
Mod. Note
Thread cleaned.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Hi William-1,
I wondered if you can help me,
I loaded the .ndf file onto my Dr HD D15 as a quick way of getting access to the channels on my fixed dish however I have encountered a couple of issues.
Firstly I flashed the .ndf to "Normal DB" then "Default DB" after, I had a little play and all looks good however, I'm unable to completely get the box to how it was before, even if I "factory reset" or "delete all channels" channels and settings still appear even after a firmware flash. Can you help?
Probably because I am struggling with the difference between "Normal DB" and "Default DB" as when I now turn the box on it tries to move my dish until i turn USALS off.
Secondly I'm now not getting any audio on the HD channels, SD are fine, very odd.
Kind Regards
Statalite
Try a factory reset then reload the channel list.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
After I do a database reset the D15 immediately tries to go to Thor 5/6/7. It then realizes there is no signal on my fixed dish. I flashed the file again to both databases but each time the box is looking for Thor 5/6/7 I suspect as "Music Channel" is on this satellite in the channel list.
Currently its not showing me any signal on anything.
Confused as to how to get it back to how it was before the first flash?
Archive-8
Have you tried changing the diseqc options, using some of Williams list, I can some times have a diseqc issue with my dr hd d15
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Whatever I do it comes up no signal. I know there was signal, any now it's gone, I have not removed the satellite cable and no bad weather etc.
If i reset anything William's settings are always retained.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
I seem to have had success with deleting the channel list totally, turning off any motors, scanning my own list just for 1 satellite, retaining william's transponder lists. At least I get a signal showing now.:)
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Thanks Chris1979 I'm sure i will find the blank file useful in the future.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Does anybody happen to have a backup of the original shipped .ndf database for the D15?
For piece of mind it would be nice to have this back.
If you do a factory reset then go to satellites you will find the original database.
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
This does not happen for me for some reason even after saving a blank database to both options the doing a "factory set". :(
Maybe the DrHD D15 does not support all the functions of the TM5402HD M1 & M2 series.
I think on reflection the TM5402HD M3 & F3/5 are the same build as the DrHD d15 so you will not be able to find the original data base this way.
TM5402HD Channel list updated today,
53 east to 45 west all satellite transponders updated,
Use this channel list with these receivers using the NDF file system:-
TM5402HD M1,M2,M3,F3/5 & TM6800HD
  • TM5402HD Ch List for 13th August 2017 by William_1.zip
mizielin
57 South - 45 West
Poland
Hello William
My tuner is Technomate TM-5402 HD M3CI, I'm from Poland. I sincerely ask you for a 2017 channel list from 60 East to 45 West because on polish forums I couldn't get any help. I would be grateful if you could help me.
