Just Sharing This New bracket for 1224
Pipedream
Sheffield
Just made this new bracket for putting a precision dish on to a 1224
RimaNTSS
Some SAT-related hardware.
N-E from Riga
How did you make it? I mean, it seems very professionally made, the ring etc. Good job!
Pipedream
Sheffield
I got 2 rings rolled from 50 x 5mm flat bar at an engineer/fabricating shop, the rest I done myself on Saturday and painted it on Sunday
Pipedream
Sheffield
It will go nicely behind the 1.5 precision when I have finished painting it. I have straightened the rim and got it into primer at the minute.
Pipedream
Sheffield
This was the 40 dish from ebay
Straightened rubbed down ready for paint.
Pipedream
Sheffield
That looks a lot straighter from when you got it :Y .... have you thought possibly about using a 10" or longer contour profile gauge by first getting the reflector profile from an undamaged part of the reflector and then run it over the damaged area to see if you have lost some surface accuracy and if so, attempt to carefully use a roller to regain the shape ? .. just a thought
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Excellent work and well done for saving that beautiful dish!
Nice work, the ring looks strong and capable of taking a larger dish than a 1.5m subject to the 1224 being up to the job.
Did you spray the primer onto the dish, the finish looks good?
Pipedream
Sheffield
I made a couple of formers about 14 inches long one for the back of the dish and one for the front, sandwiched these together with 2 clamps then with a rubber mallet tapped it around the inside of the rim.
This was the one for the back of the dish. After stringing the dish it is about 2mm out, I will have a play with this before I top coat the dish.
Pipedream
Sheffield
Hi moonbase yes I did spray the dish gives a lot better finish. The 1.2 Precision and the 1.5 IRTE I sprayed white but I think I will finish this with cream, the white is a bit bright.
Pipedream
Sheffield
Nearly finished done the last bit of straightening this morning and sprayed with a light cream top coat just the arms to put on and it is finished.
Top class job, well done, it looks really good.
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Amazing work, glad you saved it :)
Pipedream
Sheffield
Did you spray it with an HVLP sprayer or compressor with gun or did you use spray cans?
I used a small compressor and spray gun. The compressor I use is not really large enough but it does it.
The compressor and spray gun has given you a nice finish, it looks like a satin finish rather than gloss or matt?
Pipedream
Sheffield
It is Hammerite smooth, I used a mixture of white and cream just to tone down the white a bit. I find the white on its own very bright, when the sun is on it it dazzles you.
