- Oct 21, 2006
- See signature
- North Somerset
Hi , i'm also looking to buy full set of SS bolts for this motor . Any ideas ?
Or a good way to restore what's left of the old ones .. Vinegar maybe ?
Just be somewhat careful about the strength of the bolts you get - that can vary quite a bit, so you need to look at the embossed ratings on the heads of the existing ones and buy some that are at least as strong.I usually buy a set on eBay - as long as they are the same size, they will work.
The links from this page from Bolt Depot might help - sometimes 2 links further on because of Metric versus US sizes...
I'm not very clued up on Bolt measurement .
"Long nut" is often called a "Coupling nut" in the UK - available on ebay, and, I think, at Screwfix.At that piece of M6 rod you can screw a M6 long nut to pull out that spigot which is secured with a M5 screw at the opposit end .
Hammer it out from the other side after putting some tension with that spigot puller .
