Ka band dish size
Laser
Would anyone know please the dish size required for Ka Band viewing on Eutelsat 7east and 16east please.
Thank you
Thank you
Personally i wouldn't go less than a well tuned 1.2 mtr . A 1.5 or 1.8 is a good choice for good reliable signal capture of the various level of Tp levels that inhabit theses two birds. The bigger the dish size though, the bigger the installation tracking accuracy requirement becomes - a system with both AZ & EL motors helps to get over that .
Terryl
Custom built PC
dishpointer.com would give you a good estimate based on your location, enter your location, select the satellite your trying for and hit the search button.
Laser
Position is Berkshire. Just to the west of London.
s-band
Essex
Agreed. I use a 1.2m Prodelin/General Dynamics 3122 which is ex-Ka Band VSAT on an az-el so I can track non-geo. I'm not far away, in Essex, and some TPs are marginal. The VSAT Ka dishes have a better profile and more rigid construction, if you can find one. Precision/Elite used to make Ka specified reflectors but their standard ones are still good.
rs100
CM 1.0 DISH
Hi there can I ask where you got that dish from thanks
s-band
Essex
rs100
CM 1.0 DISH
