Problem with new install motorised system
Johnnics
Techonmate TM-5402 M3, Technomate TM-2600M3 Diseqc HH Motor,
Quad LNB, SKY Dish 750mm
Londonderry
Hi Guys need some help, advice on NEW MOTORISED SATELLITE SETUP
Have a Technomate 5402 M3 Satellite receiver and a Technomate TM2600 M3 Diceqc HH Motor. Quad LNB, 2 cables 1 to motor then to LNB and another straight to LNB
Have everything setup but the first thing I notice was when I tried manual button it did not move east or west checked software and deleted limits but still no movement. There is on motor power green led and a flashing orange signal to say received command then a solid orange light .Limits set atfactory 70Deg West and 70Deg East didn't check them as it means taking dish off hope its something else
second thing is two red bars I presume signal strength only left hand side solid at 96% and right hand flashing 0 - 97% 97% is only a quick flash I think its looking for signal????
First of all no motor movement and Im I right on the red bars signal strength Can anyone help.
Thank you John
Mickha
North West
Usually when the signal bars are flashing it means there could be a loose connection, which could also explain why no power is getting to your motor.
Try remaking the F Connector connections, ensuring there is sufficient braid, making a contact:
I could be wrong, but I think the TM motors have a light behind one of the manual buttons, showing when connected to power.
You might have a shorted cable between LNB and motor, and the motor will not move if this is the case.
Johnnics
Londonderry
Thanks for quick replies I do have power out at motor Green LED light up and binks amber when I give it a command then it goes solid amber
Plus I do all connecting when theres no power to make sure I dont short. Will check connections again but raining at mo nothing different there
will update later
Have a look through the thread below since you are indoors
Johnnics
Londonderry
OK update got the motor moving don't know if it was a bad connection or if cable was in the wrong output {which it might have been} ie
2 outputs on sat Receiver LNB and loop I had it in loop plus I had 2 cables going out to dish the loop one was to motor then onto LNB and the other was going from receiver LNB straight to dish LNB.
SO should I only have one cable going out to LNB via the motor
CAN i have 2nd cable going from receiver loop to LNB????
PLUS have moved to UK Astra Sat 28.2 and have no signal so have to adjust Dish and not the motor bracket setting?????
Thanks again for your help
Johnnics
Londonderry
Struggling to find channels everything seems to be set right only angle of dish might be problem but it looks same as my sky dish Astra 28.2e
which Im trying to tune to
Left Red bar at top is 96% L Right bar is 0.00db 0% I think thats channels /signal found???
have My position in Lat N54.9 Lon 7.2 W and goto 28.2E but Thats it scan channels but nothing Where I'm I going wrong?????
Terryl
Custom built PC
NO, do not connect the loop output to the LNB, the loop output is for a second receiver.
For help locating the correct direction for the satellite your looking for, try dishpointer dot com, enter your location and the satellite your looking for, then zoom into the location where the dish is mounted and click on it, this will give you a map with a line pointing at the satellite.
Mickha
North West
Your two bars are usually signal strength, and Signal Quality, the second is the most important.
It sounds like your motor hasn't been aligned correctly.
The easiest method is to zero your motor, dish and LNB, then use your receiver, using USALS, after entering your Latitude, and Longitude, to send it to a suitable satellite, preferably close to your Longitude, then physically align the dish, on this satellite.
You can try using Diseqc 1.2, to manually move your dish, using your receiver, to try to get a signal, off 28.2E.
Also ensure that you have chosen an active transponder.
Have you read the online manual?
http://www.technomate.com/support/TM-5402%20HD%20Manual.pdf
Johnnics
Londonderry
Hi set the motor up as manual the dish is by the eye as I have another dish on a wall opposite going to buy a satellite finder meter to be sure
Will the meter align the dish declination angle ???
PS: found 1 channel as it stands so everything working other than make sure alignment is right
Johnnics
Londonderry
This is why i love these forums somebody out there will help you :Y
Hi Mickha yes did read manual and did use USALS thats how I got to Astra 28.2 and try align dish same as my other dish just something not right alignment
How do you pick an active transponder?
Mickha
North West
Check satellite sites, like lyngsat, as they quite often change:
https://www.lyngsat.com/
https://www.lyngsat.com/Astra-2E-2F-2G.html
Terryl
Custom built PC
dishpointer.com will give the necessary info to get you with the ball park, this is as close to your location I can get with the lat, long you gave.
As you can see it will give you the info you need, just move the marker to your exact location and zoom in.
Johnnics
Londonderry
Thanks for everyones interest and advice will leave it there untill I get a satellite meter to tune and align dish . At least the dish is moving just alignment needed. Will give an update probably next week Thank you John
Johnnics
Londonderry
Hi Guys have the satellite all set up, meter was a gods send
This is what I found, The top 3 is probably the best
ASTRA 28.2E FTA 403 TV Channels
ASTRA 19.2E FTA 394 TV Channels
HOTBIRD 13.0E FTA 339 TV Channels
BADR 26.0E FTA 78 TV Channels
EUROBIRD 9.0E FTA 51 TV Channels
EUTELSAT 16.0E FTA 31 TV Channels
EUTELSAT 7.0E FTA 31 TV Channels
AMOS 1/2 4.0W FTA 50 TV Channels
THOR 1.0W FTA 13 TV Channels
ALTANTIC BIRD 3 5.0W FTA 12 TV Channels
ASTRA 1 23.5E FTA 12 TV Channels
I'm I missing any other Satellites that has anything good on them
Sky 750 x 600 dish and I'm in Northern Ireland
Thank you John
That very good! :-clap
And, as you can get all those, also have a look for Hellasat 4 on 39E and Turksat on 42E as both are very strong in the UK.
mike1
Non-28.2° Sat Specialist
Yorkshire Television
Triax 64cm triax ( Darkmotor ) Inverto Black Ultra.
T55 - 28E/19E/13E/1.9E
Mutant AX 51 Open PLi
GT Media V7SX
60E -Kiss TV / Prima (English Movies)
45E - City TV / DW News
42E - Power TV / TRT Sport
39E - The Voice
Dont forget these mainly a few FTA music channels on these far eastern sats.
Haven't you tried 30W?
Even 26E on such a small dish. Good job.
Next problem - what to watch...
OTOH, you have to be very careful with "26E" as, especially with a small dish like a Zone 2 because it has quite a wide "acceptance angle", you can pick up a lot of stuff that is actually on 28.2E/Astra 2.
39E - The Voice
Some transponders on Turkmen/Monacosat at 52.5E are receiveable on an 80cm dish and so you might be able to pick up those up - but 60E is probably not doable.
