Advice Needed New build satellite system
Edgeyboy
Sky Q
Cambridgeshire
First post...
I am helping a friend who is building his own which is near to completion, on the data (all sorted) and TV / satellite distribution system.
There are 3 bedrooms, a kitchen, living room and summer house (6 rooms total) to feed with TV/Freesat. The living room may have a SKY Q box in the future too so has been wired with an extra two CT100 cables. All six rooms have been wired with 2 no CT100/WF100.
I have been recommended the following products for the commissioning stage of the install:
Terrestial TV Aerial
60cm or 80cm Satellite Dish with Quattro LNB
2 way Vision dscr multiswitch + PS
12 way Vision multiswitch + PS
As I understand it, it will work as follows:
Outputs from the Quattro LNB feed into Vision DSCR cascade multiswitch. 2 outputs to SKY Q in living room. 4 outputs then feed to Vision 12 output multiswitch which supplies the 6 rooms (2 each: one satellite, one terrestrial tv).
Does this sound ok?
Thank you for any input.
Tom
I would stick a hybrid LNB outside, run all six cables into the point where all cables get sent out and use a distribution switch with fixed four port voltage/22kHz settings.
But the choice is yours.
Edgeyboy
Sky Q
Cambridgeshire
Thank you. Would you be able to expand on which switch might be good? Originally we were going to use a Delta 16 port switch (and send Sky Q straight to wall points bypassing this) but I was told that the solution I listed was more robust and better at long cable runs. Thanks agin
It's been a while since I installed one, but Spaun always had indivdual settings for their SMATV boxes, allowing a quad LNB to be installed without trouble.
Others off the top of my head would be Fracarro Switchline (ex Philips) and Triax (via Farnell)
I have a delta 8 way unit lying in the shed, and I think it also had dedicated 14/18/22k on each port, but would need to look at the specifications
I would use dish with Quattro, an 8 way multiswitch and four universal outputs from that feeding into a Triax TMDS 42c, that would give you 6 legacy feeds with Terrestrial and 2 dSCR/Legacy feeds with Terrestrial for the lounge.
If there are already dedicated Q cables run I couldn't justify the the money on legacy equipment when terrestrial is catered for in the main amplifier.
(but I would need to check pricing to be sure)
Since the Q system is only good for three points please let your friend know this should be treated strictly as secondary.
Have to say that if I were installing the system, my recommendation would be a Terrestrial feed to all rooms and a pair of wideband feeds plus a Terrestrial feed to the living room, unless of course the customer already had a Sky HD system that he wanted to maintain, or already owned Freesat PVRs, otherwise as Channel Hopper says above, the Legacy multiswitch and equally the dSCR is an unnecessary expense.
davemurgtroyd
Oxford
Oxford
Q I believe caters for up to 5 points but only 3 can be used at any one time.
Which means for the 2.4 kids and poodle family, its a three point system.
