Red alert
- Dec 21, 2019
- Age
- 39
Inverto ultra 0.2db, Edision Mio 4K, 1m Gibertini XP on Superior Dark Motor.
R.I.P -> Technomate M3 and Stab HH100.
- Manchester
Yeah LNB is checked and works best when pushed back. The weird thing is when i very slightly change the elevation on the motor it doesnt have much effect on the results. With most declination settings either up or down a few mm i notice 26 east always needs to be pushed slightly to the right. So when it comes to moving the motor mount a few mm to the right when motor is at 0 then signal quality goes down on all other sats. I also tried using 5 west also to align dish/mount and noticed a very small improvement across 5 west to 23.5 east, but nothing on 26 east. I can only pick up 1 freq on 26 east. Also when i change declination on motor i notice moving mount left/right doesnt make difference to signal quality on 1 west. Would there be a difference if i align dish on 5 west rather than 1 west?Have you checked that your LNB is sited correctly, by sliding it back and forth?
I still think you might need to do some gentle tweaking, unless you have obstructions, at 39E and 42E, blocking the signal.
Try to ignore the dish bracket information, this is usually just a guide, and try adjusting your motor angles, slightly, then compensate by adjusting your dish bracket, to peak the signal quality, on 0.8W. But always make a note, of where they currently are, so if it gets worse you can quickly move it back again.
Then check the signal quality readings, on the satellites.
