OCTAGON SF8008 E2 4K UHD
Laser
Thank you.
If you download the latest do you think that will sort it out?
The issue would have been with one of the OTA updates, not the 6.4 itself (though I did have some odd effects when I first started using it)
Whilst some sites confirm 6.4 as beng stable, there are others that suggest it is an advanced beta release, so perhapps there is some further work required.
cardiff
Brittany
Laminas As 1800, multifocus 14 LNB
France
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Zorbua. Mine exactly. Gets to 100 and keeps going back to 50. I'm on 6.3 and have no USB stick with 6.3 or 6.4. ATV on it. Have looked through the thread and can't see a link.
This is the link I use for the OpenATV6.3 openATV Nightly Downloads
When you download don't forget to add the usb_update.bin to the zipped file (I used the 6.2 Image usb_update.bin)
The 6.4 image is highlighted as out of date by the SF8008 on an update (and the same lock occurs after the completion)
Will try 6.3 tonight.
http://www.octagon-germany.eu/
OCTAGON SF8008 4K UHD E2 Fastboot & Recovery Update 25.04.2020
- [SF8008] + [SF8008m] Update:
* fixed crash driver when press any rcu key
* fixed crash when load more as 3 Image to same time
* add delete image from slot (Multiboot Deletion)
* add common partition update get latest recovery menu
* optimise install performence
* stop der installation wenn fernbedienung betätigt wird
* fehler bei nutzung min. 3 Images behoben
* löschfunktion images auf slot x eingebaut (Multiboot Deletion)
* Hinzufügen eines allgemeinen Partitionsupdates (eueste Wiederherstellungsmenü)
* Installationsleistung optimiert
Wenn Neue Multiboot + Recovery Image genutzt wird, reicht ein Online Update!
If new Multiboot + Recovery Image is used, an online update is sufficient!
Yeni Multiboot + Kurtarma Imaji kullaniliyorsa, online güncelleme yeterlidir!
OCTAGON GERMANY SUPPORT
I loaded up 6.3 image, but the 8008 continues to show what I think is the 6.4 start up screen (black ‘A’)
Is this normal ?
OCTAGON SF8008 4K UHD E2 Fastboot, Recovery and mkupdate Update 29.04.2020
* fixed crash issue when press MENU on submenus.
* fixed issue when using a big usb_update.bin(big rootfs) to update.
* so now you can generate a usb_update include more then one images.
* keep at least one image on the box when you want to delete all images.
* buildimage update to 1.1:
* fix kill with large rootfs (mkupdate)
* modify for PVR streaming
4:2:2 Feeds (Feedhunting) mit OCTAGON SF8008 4K
Vorab Infos
Wikipedia Feedhunting:
Feeds immer aktuell nach Rubriken:
Installation per Telnet:
opkg install kodi-addon-pvr-vuplus
install pvr client
Kodi starten und im E2 Client IP Adresse vom SF8008 eingeben.
"scanne tp 4:2:2, du hast in der e2 ch liste, starte kodi, öffne pvr client, sie zeigen automatisch die ch liste enthält 4:2:2 feed kanäle"
Viel Spaß!
Advance information
Feeds always up to date by category:
Installation via Telnet:
install pvr client
Start Kodi and enter the SF8008's IP address in the E2 client.
"scan tp 422, you have in the e2 ch list, start kodi, open pvr Client, they Show automaticly the ch list include 422 feed channels"
Have fun!
After a couple more tries the box here is unable to to download the 250 or so updates that are held at Octagon HQ (or is it the OpenATV HQ ?), with the message saying I should update the firmware.
I'm given a choice on screen, but no matter which one I do the receiver refuses to restart, with the same 'hanging' issue of three weeks ago.
I'm able to reinstall using the fastboot and recovery service rather than flash from USB but this just takes me back to the same version, regardless of whether I chose 6.3 or 6.4.
Should I be reverting to 6.2 or even 6.1 for the receiver to install the missing upgrades ?
Laser
These overnight updates are not tested thoroughly before release. I have 2 receivers both are out of use due to updates of 3 weeks ago . Makes you think twice before buying them for sure.
I have not checked if I can remove some of them before updating perhaps choose the first 50% and then go in stages towards the full number.
Is that possible or do you have to carry out the lot in one go ?
TJExcalibur
Out of this world.
Southern England
I have Openvix on mine. Did the Recovery EMMC and its all working a :-biglaughtreat.
I think the Kernel version has changed hence you cannot update from the USB. If ATV is the same as VIX, enter the 'Software Section' and 'Image Manager' and you can flash from there, either by a download if you are LAN connected or by FTP transferring your new Multiboot image to the 'Imagebackup' folder then you can flash.
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
So I was getting a blue screen after scanning 33E and watching France 24, thought I would install the 121 updates now the box won't boot up. Stuck on 100 on the sf8008 display How do I reset please ? I presume I have to install Open TV all over again
TJExcalibur
Out of this world.
Southern England
OpenVix do a recovery EMCC in their downloads. I expect OpenTV do one.
Laser
Same thing happened to me. They don't test the updates properly before release.
I have 2 boxes out of use now.
Let me know how you get on please.
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
So this worked for me. Not inslalled any image but I give the link for Open ATV 6.4 after the guide here from WOS forum
1) Download latest Enigma2 Image of your choice.
2) USB 2.0or 3.0 minimum 2 GB USB stick formatted with FAT32.
3) Unpack the image and copy BOTH the 'octagon' folder and the 'usb_update.bin' to root of the USB stick.
4) Turn off the box.
5) Plug the USB stick into the USB 3.0 port on the right side.
6) Press and hold the standby button and power on the box until "Updt" is displayed.
6) Select "Recovery From USB" from TV screen menu.
7) Box restarts when update is completed.
OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 01.06.2020
* add sx88/sx88+/sx888 rcu support.
* Remote Contols as:
* SX88 /+/SE/WL, SX888 IP/WL, SX88+ Optima & Combo.
* sx88/sx88+/sx888 Fernbedienung support eingebaut.
* Fernbedienungen wie:
Info:
DE, Auswahl Menü mit mehr Optionen & Fernbedienungen später!
EN, Selection menu with more options & remote controls later!
Can this be disabled?
