Advice Needed Famaval 2.4 informations
abougouda
2.4 famaval , vu+ due
egypt
Hi, i got famaval 2.4 and i need all info such as the best focal distance and best feedhorn and the depth of that dish because i am gonna go to made special feedhorn ex. scalare range 3m or 2m or 4m
Why not look at the dealer/manufacturer's website ?
RimaNTSS
Some SAT-related hardware.
N-E from Riga
If you wish to have everything "the best" then you better get best dish :-rofl2 not Famaval. Just kidding.
Welcome your first post! If you have a chance post some pictures of your installation.
abougouda
egypt
I did but nothing about what i asked
Since you have the reflector dimension, if you measure the depth of the dish you can work out the 'best' focal distance.
abougouda
egypt
Done
I got this measures in the attached pic.
Now i need the best scalare range protrusion for that f/d .40 and i made that feed
The manufacturer has specified their reflector diameter is 2290 mm, do you have a different design ?
abougouda
egypt
Yes i belive i have the first design of famaval pure 230 cm and you can check picture of my dish not the same one in web and also dont have the 24 hole for extra petals to be 310 cm and arms on edge not inside this why i ask for help
If there is no hole in the centre of the reflector then it is a pressed design, Famaval from memory is spun aluminium, unless they have changed their manufacturing procedure at some point.
Or is it the other way round ?
abougouda
egypt
There is hole in center
