Ka-Band Satellites
s-band
Essex
Re: 42 East Ka ....
Can't make my mind up if the signal around 18705 L is two small ones or not
Just one and the carrier at 18598.50096MHz is just that.
Plot using a band B LNB and clipping the roof line so I don't get much SNR. Uncompensated for gain slope.
SimonE
Gloucestershire, UK
John,
I use a CM 1.2m dish on an H to H mount with Elevation adjustment. The LNB is an XMW R9216AF with a PTFE slab imported from South Korea. I am also unable to resolve the signal on 18705L. I wonder if there's a different beam for that signal?
Simon.
John,
Simon.
Just looking back to March 26th - 2018 Simon, almost identical plot then but 18.701 L looking a lot stronger with me just north of Nottingham.
dx qwer
www.satellitescommunity.de
C-Band: ORBITRON O-16 (4,9m)
Rastatt/Germany
just my try on 18705 L, too weak signal for showing stable video content on analyzer.
Best regards
qwer
SimonE
Gloucestershire, UK
I checked the satellite this morning and only 18591L and 18668L locked up. On 18668L Capital TV Ghana has left. 18591L is very robust with its fec=1/2.
Yeah, had a look around mid-day with quite overcast skies in the signal path and levels were really low as well.
@ 19° East Ka
19° East Ka Hor.
I have these four showing today down at the lower end of the band.
18.419 H
18.417 H - very strong signal for last few days.
18.410 H
18.405 H
Just APSK John. No idea of the source, but strong here.
dreamsat
germany
Hello ,
here is the transponder with TBS 6983 and 1,20m:cool:
best regards dreamsat
dishdx
www.dxing.cz
Showbox Vitamin, Octagon SX88
Dishes: Offset motorised 120 cm 40W-75E IBU Twin, Channel Master 180 78.5E-30W manual rotate , Cahors BigBisat 8 x Alps 1W,5E,9E,13E,19E,23.5E,28.2E,39E. Planty of equipments for FM and AM DX. http://www.dxing.cz
Central Bohemia
Hello, where I can buy Ka Band D LNB? Do you have some tips?
19.2° East Ka.
Some Blue light activity here in central UK this evening - 18.511 V
Chemical explosion at 11.22 this morning, classed as a major incident at a recycling plant Nr Bristol - four people killed.19 East Ka.JPG
Not too sure if i have seen this one documented before on 7East Ka
