EBSPro, CrazyScan Tips&Tricks Newbie Questions
There is no error or crash with the tbs5927 card scanning low symbol rates at 23.5E.I used Crazyscan,EBS,Dream DVB and SmartDVB and all apps have locked these low symbol rate.
regards
dishdx
www.dxing.cz
Showbox Vitamin, Octagon SX88
Dishes: Offset motorised 120 cm 40W-75E IBU Twin, Channel Master 180 78.5E-30W manual rotate , Cahors BigBisat 8 x Alps 1W,5E,9E,13E,19E,23.5E,28.2E,39E. Planty of equipments for FM and AM DX. http://www.dxing.cz
Central Bohemia
Ok, i will test it on another pc and will write. Scan of tp is also no problem, only try to playing and smart crashes :-(
EnoSat
enosat.euweb.cz
Slovakia
tuner works from 950 to 2050
5150 - 950 = 4200
5150-2050 = 3100
tuner work from 300 to 2500 ( only on out range occasional crazy)
dishdx
www.dxing.cz
Central Bohemia
Exemple where i have problem. When i want run TSReader on the TP selected lower it stops working - EBS freeze and i need to kill them with task manager. I think that here could be problem with my unstable LNB Inverto Black Ultra (+- 1 MHz).... Probably can´t lock and no timeout to cancel the operation?
P.S. I use Stephan´s methode for LowSR and works perfectly!
stephan94
Bavaria
It may be a problem of trimming between TSReader and EBSPro.
does this happen also by calling the tool "search and analyze transonder"?ebspro.jpg
dishdx
www.dxing.cz
Central Bohemia
Hi! I still have the problem on SR <500 on all of the DVB SWs like SmartDVB, AltdDVB, ProgDVB etc... It crashes! In smart DVBS is possible to see debug info, other crashes totally or with BSOD with reason "tbs5927.sys" crash and i need to restart pc. I cant play SR<500. Only one way is CrazyScan + VLC, and sometimes EBS+VLC.
I use Windows 10 64bit, TBS 5927, Win 10 driver version 1.0.4.
How is possible to solve this problem? Where is problem? In device? In driver? What can i do? Should i send the device back to seller for repair?
  • smartdvb-logreport.zip
CrazyCat
crazycat69.narod.ru
13E 4.8E 4W: Dish Variant CA-902 0.95m + 3xLNB Ku-Universal DreamSat DS8 + DiseqC 1.0
30W-95E: Dish Strong 0.95m + LNB Ku-Universal ALPS BSTE8-751B + Motor PowerTech DG240
OpenBox X-800
TT S-1401 PCI
Omicom S2 PCI
TBS 5980 USB2.0
Ukraine, Kharkov
dishdx
www.dxing.cz
Central Bohemia
Crazycat, Thank You for info. And how can i solve it? Exists some other driver than the official one on the tbs website without this bug? Or will it be repaired? I have this problem cca 6 months and the driver on the web is still the same... Thank you for help. I use your Crazyscan for detail analyse, but for normall watching/listenig i use SmartDVB and ProgDVB and with this bug i cant listen interesant radios:-(
driver bug
CrazyCat
crazycat69.narod.ru
OpenBox X-800
TT S-1401 PCI
Omicom S2 PCI
TBS 5980 USB2.0
Ukraine, Kharkov
SmartDVB can work via my StreamReaderEx (some like CrazyScan Blindscan device). And latest DVBDream 3.x also have similar device module.
dishdx
www.dxing.cz
Central Bohemia
Bad news. It doesn´t helped.. Smart DVB still crashes:-( Interesting is, that 6 months ago i had no problem to receive low SR on Crazyscan/EBS (SWith smart i had same problems like now) and now i can´t lock nothing below 500. Blindscan find this tps, but no lock. I thought that in winter will it be better than in summer. So could it be some hw problem with receiver? Its is strange. Above 500 no problem with Smart and EBS, below 500 problems in both SWs..
LNB is IBU! (+-1 MHz). I know not good for low SR... but could this do this crash problems??
stephan94
Bavaria
Hello,
today, out of curiosity I tried to use SmartdVB.
my installation (among others) : KU Band LNB with disceq 1.1 command 4 (TBS6983)
I work with a windows 64 PC
I have tried all possibilities, I can't get the signal (with AltDVB OK)
If someone can tell me where I make a mistake ?
cirio70
Laminas 180 - Fracarro UX-TW-LTE(PLL) - C Band - TBS6903 - Octagon SF 8008 -Zgemma H92S
Lombardy - Italy
i use Florian BDA device and disecq Committed LNB4
It's the only way i can make it work even if i usually use AltDVB
Hope this helps
Why use the DiSEqC command when you can access it directly if you don't have a DiSEqC switch?
For diseqc 1.1 choose uncommited.
cirio70
Lombardy - Italy
I don't know if you're talking to me but i have a Spaun SAR 411 switch and i must use committed to make it work whit ALT/SMART DVB
MrDish1
Delta Star
Qth:Aalten
A question;
is the (SR) next to the polarization in the columns ?!
And you can determine / fill in the values yourself.
Best regards
MrDish1
Delta Star
Qth:Aalten
A question;
Best regards
All that is a question.
cirio70
Lombardy - Italy
A question;
Best regards
Yes, of course, you can input all the values shown in the picture.
In the left panel you can find presaved frequencies stored in a .ini file.
In the right panel you can manually scan a TP fillin in all the needed parameters
stephan94
Bavaria
Hallo , using 0.5.1.1 x64 Beta1 it works perfectly.:Y
with 0.5.3.26 x64 Beta 1 it does not work. :confused
MrDish1
Delta Star
Qth:Aalten
In the left pane, you will find pre-saved frequencies stored in an .ini file.
In the right panel you can manually scan a TP fillin and fill in all the necessary parameters
And where can I find that ,the left and right panel.?!
