Eutelsat 13C now called (Eutelsat 12 West G @ 12.5° W)
it pass 7.2 west it move west
Remember when the satellite stops the readings will not immediately be updated as this is an automatic readout & needs to be manually updated,
So we will have to wait a while for the correct readings.
It's still continuing west... the TLE is correct.
the hotbird 13c move west it near 8.9w
the hotbird 13c it pass 13.5w move west
It appears to have stopped at 12,5°W. The TLEs report it at 13,5°W, while taking the Eutelsat 12WE (ex W2M) telemetry signal as a reference, they appear to be in the same position (see video).
In about 24 hours, I'll check again to confirm...
This will make 12.5° west very interesting for feed hunters again :)
The satellite HB-9 / HB-13C has been designed to cover all 102 Ku-band transponders 10.7 to 12.75 GHz
So I will start my blind scan on the lower part of the Ku band 10.7 to 11.7
11584 H 7532 DVB-S fec 1/2 is the first active I will need to check this out as there are 2 other satellites nearby
Express-AM44 @11W & Eutelsat 12 West E (E12WE, Afghansat 1,
maybe near 11w feed ?
EnoSat
enosat.euweb.cz
Slovakia
11584H has been at 11W for a long time
I confirm, it is at 12,5°W.
Test carriers have also been activated.
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
Curious what it's purpose is, Is there such a shortage of space around that area for feeds?
Yes 8 years ago 12.5west & 24.5 west were very active for feeds so HB3C will be very busy when it starts here.
SatSearcher
West Yorkshire
I was hoping it would go to 12.5W, it was a fairly interesting position a couple of years ago, used to carry the Italian multistream services amongst other things, let's hope for something interesting!
But since leaving 13°E, starting to build inclination, it's 0.13° now.
So likely no DTH broadcasting, maybe feeds, or data like Eutelsat had for long near 48°E.
I guess it will be called 12 West G.
