Upgrade to xenforo 1.2 completed
chris
TalkTalk TV
Worksop UK
Upgrade to xenforo 1.2 completed, please report any bugs.
Made me a bit worried when I got an error, especially as the next site I tried was also suffering a temporary problem! Thought I was the source.
Will keep a lookout for glitches.
Probably on your list of things to be done but the forum logo is missing from the top of the page.
Multi delete now works on private messages, although its a slightly illogical way of doing it.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
I've posted new post in "My Sat-playground", but after pushing "new posts" it does not appear in the list.
<br> <br>
Looks nice.
It's "new" for all but the Poster ................ :)
No change from previous version.
Yes, you have to then click on Recent Posts to get the full list. A right PITA.
I'm sure once he's got the major bugs fixed, Chris will be able to put a recent posts link next to new posts.
Edit. Just got this error whilst trying to post this using the quick reply, had to go to more options to get it to post..
Yes Ive had that one a couple of times as well Rolf
Moderation Queue box is AWOL.
I was going to check if Logging Out and In again resolved it, but the Log Out option is also AWOL ! :-rofl2
chris
TalkTalk TV
Worksop UK
Logout button is under your user menu. Click on your username in the navbar next to the inbox link then bottom right of the popup box you will see logout.
So it is, thanks. Logged Out and back In >> The Mod Q button is still missing, though
chris
TalkTalk TV
Worksop UK
Missing for me also, will check it out.
chris
TalkTalk TV
Worksop UK
The moderation queue link only appears when there are items to moderate.
Ah, I did wonder if that might be the case.
Ok :cool:
Can the "New posts" link be made into "Recent posts"?
TapaTalk doesn't work but that's already known.
Please make it soon Chris as the Recent Posts button has now disappeared off the page after you've clicked it once and using F5 doesn't then bring in the new posts.
