TurkmenAlem/MonacoSat 520E (52.0°Ε)
Oh, that's quite much offset! Maybe the grid as used by some Eutelsats ( 7A/7B/36B ) is used then:
10720.75 - 10762.25 - 10803.75 - 10845.25 - 10886.75 - 10928.25
11220.75 - 11262.25 - 11303.75 - (circa 11344 - 11382 - 11420)
Great, so frequency-wise it's all clear!
I guess only the associated beams are still unknown to you, and therefore you call the plan provisional?
How to retrieve this at ITU, is it under SNL or SNS, and does it need subscription ?
Once again, thanks for continuing your unique investigations! :-clap
Those information can be found in the archives "SPS_ALL_IFIC and 30B" to free access.... The operators can change the frequency of the transponder, but always remaining within that range of frequencies. But those of monacosat seem correct.
Yes, I do not know yet how they are interconnected the beam.
tempo
47.5N, 42.2E / Russia
A hour ago testing returns back. Test carriers 12226V, 12303V, 12380V, 12456V
tempo
Several wide-band test carriers are active at the moment
Now that the 120 cm Laminas is operational again, I can finally see the tests!
Indeed, these two wideband tests come booming in. Similar dB readings.
shawl_who
SES7, Yahsat 1A, Yamal 54.9e, express am33 @103e, eutelsat 36b
New Delhi, India
which beam the channels are on, east or west beam ?
puteez
Octagon SF4008- 90e-0.8w
Ukraine
12226 V 29990 5/6 dvbs2
there was a package of channels to the 75е 11605V43200
