EUTELSAT 8 West B
eutelsat 8b live on air
daaihe02
Channel master 120 cm .
Sweden
I live in northern Sweden . I have channel master 120 cm and Inverto black ultra . The frequency 10971 V 27500 3/4 is very weak here 15 % , i hope it get stronger next few hours.
About 7 dB here. Gibby 1.2.
2night
vantage hd 8000s
120 cm dish
windows 7
friesland (nl)
12645 h 27500
10971v sr-27500 fec 5/6
15.5db
11012h sr-27500 fec 5/6
19db
11055h
sr-17000 fec 5/6
21.5db
11096h
sr-27500 fec 5/6
19db
11137h
sr-27500 fec 5/6
17.4 db
11179h
sr-27500 fec 5/6
16.9 db
12520v
sr-27500 fec 5/6
17.3 db
12560v
sr 27500 fec 5/6
18.3db
12603v
sr27500 fec 5/6
11db
12603h
sr27500 fec 5/6
15.8db
12644v
sr27500 fec 5/6
18.1db
12644h
sr27500 fec 5/6
17.1db
12685v
sr27500 fec 5/6
17.7db
12727v
sr27500 fec 5/6
14.5db
pikmaxx
Strong 4620 reciever , 90 cm Dawlia dish
South of Iraq
19db
11055h
sr-27500 fec 5/6
21.5db
11096h
sr-27500 fec 5/6
19db
11137h
sr-27500 fec 5/6
17.4 db
11179h
sr-27500 fec 5/6
16.9 db
12520v
sr-27500 fec 5/6
17.3 db
12560v
sr 27500 fec 5/6
18.3db
12603v
sr27500 fec 5/6
11db
12603h
sr27500 fec 5/6
15.8db
12644v
sr27500 fec 5/6
18.1db
12644h
sr27500 fec 5/6
17.1db
12685v
sr27500 fec 5/6
17.7db
12727v
sr27500 fec 5/6
14.5db
Solly; did you forget 10971 h & 10971 v ?
11055 h works with SR 17000 not 27500
11636 v also appeared
All the verticals in the range 12500-12750 are on the east beam + 11636v
All the horizontals in the range 12500-12750 are on the MENA beam.
All frequencies in the range 10950-11200 are on the MENA beam .
let me test again
page 2 eutelsat 8b
it right itprovider of osn 11055h sr-17000 fec 5/6
21.5db
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Can get all the Horizontal beams here except 11055 H 17000 (although almost) but the Vertical ones (in the range 12500-12750 East Beam) are a no go.
Signal levels for the receivable ones are between 15 db to 16.5db.
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
Picking up in Scotland:
10970v
10970h
11012h
11095h
11136h
11178h
12604h
12645h
Plus usual feeds 12500 to 12750
No breakup on channels unlike 7 degrees west when the evening is best for viewing. Nice to see improvement. It it have been better if they had put this satellite at 7 degrees west as the audience for both positions is more or less the same.
Receiving most in the lower band on 90cm Fibo here with 12604H drifting in and out of lock. Not sure how much under lock the other ones in the high band are since Vu+ won't give me SNR under lock.
2night
vantage hd 8000s
120 cm dish
windows 7
friesland (nl)
hoi,
eutelsat 8 w a.m. feed now 12655 v 5000 dvbs-2 (instead of 12528 h)
marqeur now 12585 v 2222 (instead of 12627v)
Anonymous_1
French feeds frequencies plans for:
France 3: from 12546 V to 12570 V
TF1/LCI: from 12573 V to 12608 V
Tururu
Assembled with recycled parts
Recycled as the owner.
Madrid very strong levels, 90cm/Niveles muy fuertes por Madrid, 90cm.
10971 V 27500 3/4.- 13.0dB
PS: Some pictures, now I look at the rest, good fishing.
PD: Unas fotos, ahora miro el resto, buena pesca.
MCelliotG
Thessaloniki, Greece
This is a nightmare, in Northern Greece signal dropped from an average of 16db to the absolute zero!!! :(
It's crazy how sharp the footprint is on this orbital position!
Northern Greece is just outside the footprint. Surprised you're seeing nothing at all...
MCelliotG
Exactly! Which means either the real footprint ends furthersouth or the footprint that was published is rubbish... what's more suprising about this orbital position though is that I receive 10719 and 11660 from 7WA for about 15 hours a day (mostly night)!
And even crazier, all Nilesat 201 frequencies come very well at about 8.5-10db 24/7!
Very disappointed with the new satellite, it's not the first time though! I can clearly recall when I lost all frequencies from AB4 when they moved to the 7WA MENA beam!
