31.5W (Intelsat 25)
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
Post #75 above was with the TM5502HD + 100cm Gibertini still 75% Signal Quality
Below 88cm + TM5302HD
I have never been able to get Intelsat 25 with my 88cm before so what is happening is there another footprint from 31.5 west ?
Got Cherifla TV for the first time today at 4db. No chance on the other 2 channels as fec is 7/8.
I've never had issues with 31.5W. I was even able to ORTMs on 1.2m dish with a little tweaking. It's absolutely fine with the 1.8m and Cherifla is booming in at over 14dB. There must be a heck of a sidelobe and drop-off...
Archive-8
Ditto the 1.25 gibertini and sat card would lock all transponders.
And on the 1.5 I can lock and watch, all 3 channels.
Cherifla is OK with me at 10db last night on the 1.8, but couldn't lock the other two...will try tonight.
pontiend
Contibruter
south yorkshire
I think that this is a first for me on this satellite.
12284V 2200.
Only 4.4dB 47% good video and sound though.
TBS6983 100cm Dish.
Laser
Still coming in with 70% SQ in Berkshire. On 1.1 Triax Dish
12284 vertical 2200
For signal strength / location info........ i tried it last night with a lashed up Octagon Twin PLL lnbf on my 1.8CM approx 17 miles north of Nottingham and could only lock 12284 V on a TM 5402 M3 receiver at about 12dB but couldn't lock the other two -- 12340V & 12344 V as they were down to about 4dB with me.
Today, 12248V is stronger at about 15dB, the other two now lock at about 6db.
I'll re-fix and align the temp lnb correctly and have a re-measure.
nelson_b
Contributor
These transponders have always been odd ones for me here .... sometimes in the past i,v picked them up on a 1.2 cm .... and at other times unable to lock them on 1.8 .cm. ? will have a look later if i get time and report my findings ....
blademedia
Sky
September looks like a good time nelson good luck :)
nelson_b
Contributor
Hi --- results here this afternoon at my location with 1.8 c.m. - are about the same as your result last night.......
"12284 V on a TM 5402 M3 receiver at about 12dB but couldn't lock the other two -- 12340V & 12344 V as they were down to about 4dB with me."
With the 1.2 c.m i get 6.8 db on 12284 V and 0.0 db from the other two ....
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Cherifla is very strong but ORTM are weak, in fact they just cut out just now. Using 1.5Dish.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
They both came up again.
Very thundery and overcast here so all signals are down across the arc. ORTM just about lockable still.
For satellite stats collection only ..... there seems to be a low level beacon type frequency showing at 12585.75 V
Can't see a beacon freq listed for this bird or any on either side of it. Second opinions welcome
Shaun the sheep
