Advice Needed 2 way splitter
Gladstones
Zone 2 Fixed @ Astra 2
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Hi Good afternoon
1. Using a two way splitter cause any signal strength problems.
2. Can I use two receivers on motorised dish.
Thank you in advance if anyone can answer
It will not work as it is only for use with Digital Terrestrial signals via an aerial not for use with Satellite TV the way you have mentioned,
You need an A/B manual switch.
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
SSL Satellites 2 Way Satellite Splitter For Freesat
It’s on amazon someone mentioned in review that he is using with motorised dish
It's probably a bogus review. Signal splitters do not work for satellite reception except for some very special circumstances.
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
What is the best solution
As William-1 says, an A/B switch. Although these do not work well with a motorised dish. Maybe USALS but probably nothing else.
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
What kind of A/B switch
Where to buy ?
You could possibly use a stacker/destacker, they do one which is DiSEqC compatible, you just need to install a twin LNB.
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
Why not an 'automatic A/B-switch': a sat priority switch (or 'master-slave switch')?
Several setups are possible, with single LNB or twin LNB, all depending on what you want. You are not very elaborate on what you want.....
Greetz,
A33
Edit: solution for a 2 receivers - 1 motor - twin LNB is e.g. here (in dutch!):
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
I want to keep single feed lnb cable ends inside front room from there I want to take new cable to kitchen for 2nd receiver
Only 1 receiver will be on at any time
In that case a Smart Priority Switch like this one should work. I have 5 in the dish farm system ATM, and they are certainly OK for controlling both DiSEqC 1.1 switches and USALS motors using both my TM5402 M3 and SX88+ as the two receivers "in control as required" (but one of them must be OFF/in Standby for the other one to take control).
There is some signal loss, but I've not found that to be a particular issue.
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
regarding post no. 12
You mean this one
SSL Satellites 2 Way Satellite Splitter​
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Might do :confused - but since the CPC price is less than £17.50 before VAT, then you would probably have to pay £5 or so for post and packing.
Might do?? They do work very well with no loss, I have the 4 and 8 way versions.. He might get one cheaper off the bay..
