31.5W (Intelsat 25)
Модератор
You need at least 6dB (maybe slightly more) to lock on ORTM. I get 6.5dB and it's with freezes. ORTM2 is stronger at 7.3dB down here.
I believe SatSearcher managed to lock this on his Channel Master 1.2m and nelson_b on his 1.8m.
SatSearcher
SatSearcher
1m orbital dish with 0.1 Technomate LNB. TBS 6903 & TBS 5925 Card & Octagon SF4008. 39E-55W.
West Yorkshire
No not me! Think you got me mixed up with someone else! I have tried these on many occasions but never managed to get a sniff from my location.
Модератор
Ah, it was 007.4... but again on 1.8m dish.
aceb
aceb
Prof Tuner 7301 /
Sussex
Can someone try these two for me please. I've spent a few days this week putting my 1.2 back up, when it was on the test mount in the garden at the beginning of the week I was getting both signals fine but since putting the dish back up on the house I've been unable to lock them. I was starting to suspect my alignment but I've just noticed a huge carrier from 30W on 12341V 27500 3/4 and am wondering if this has come up this week and blocked 31.5?
nelson_b
nelson_b
Contributor
Strong 4375 driving 1.8 C.M. offset + Inverto Black Ultra twin + BSC 421 and Zinwell C band l.n.b.,s - DR HD F15 - TM5302 and Skybox/Openbox M3 - HD receivers.+ other dishes in use - 2.4 CM offset - Alcoa 1.8 P.F. - C.M. 120.
north west yorkshire
hi -
i,m seeing a weak signal from 12341 - 12348 V 2121 here using 1.8
nowhere near a lock though -- not been here for ages, so don,t know if its recently weakened
cheers
aceb
aceb
Prof Tuner 7301 /
Sussex
Thanks Nelson, maybe it was just bad timing this carrier came up, I'll try again later to see if the signal has come up but it's tricky to spot it amongst the strong signals from 30W.
Модератор
I just put my Ku LNB back on and ORTM2 is still there but around 1dB weaker... I cannot seem to fish out ORTM though - it gives me ORTM2 there.
aceb
aceb
Prof Tuner 7301 /
Sussex
Still nowt here, this is starting to bug me LOL Too cold to start messing with the dish today but I might try adjusting the focal position of the LNB just in case.
Модератор
I must say that it was very sensitive to alignment. One or two clicks the wrong way and I lose it.
pride21
pride21
Sandown Isle of Wight
hi aceb i got both transponders about a week ago with strong quality i tried the other day its showing about 40% quality but not enough to lock dont know whats going on.
aceb
aceb
Prof Tuner 7301 /
Sussex
Bit of a mystery then Pride, I'll brave the elements tomorrow and nip up with the laptop and give the dish a poke to see if it'll lock too much of this white stuff blowing about to do it now.
aceb
aceb
Prof Tuner 7301 /
Sussex
The 1.2 is back on Ku now and I'm now getting this one again at 7dB, what is obvious from Crazyscan is the strong carrier on 30W has gone so it must have been blocking 31.5W. Interesting to compare signals between the two dishes as the 1.8 is still on Ku, these screengrabs show how the bigger dish not only has over 2dB more gain but much better directivity over the 1.2m. All bar the locked 31.5W transponder are from 30W.
Equipment as per my profile on the left, 10m of CT125 on the 1.2 and 30m on the 1.8m.
Модератор
Yep, the beamwidth of a larger dish will be narrower and hence be more directional. Hence the need for a more precise alignment on those.
pride21
pride21
hi aceb tried this one today got both back as normal the strongest tm2 is 65% quality.
Модератор
Yep, signal is back to normal here.
remlap
remlap
Wales
I can also get 11934 V 30000 2/3 8PSK DVB-S2
pride21
pride21
hi all tried this sat flysat gave this transponder as 12283V 2198 never had any transponders for quite a while but this one came in at 41% qualityPC220027.jpg
Модератор
I am getting a 5db lock on this TP but it takes so long to get a lock due to low SR that F15 never waits long enough for it to come through. No problems with ORTM transponders though.
pride21
pride21
hi CJ what sort of signal are you getting with the others
Модератор
Between 6.5 and 7dB (variable). It's on the limit but the image is stable.
