7020 Images
gameboy
gameboy
Ding Dang Doo
Scotland
The K*y sets are normally dated
Find today's date and match it with Mgcamd or Newcamd and you should be OK
M
marty01
dreambox 7020 learning
ireland
Hi just a bit of help how do you download k+ys i can only see 13.11 05 and stil does not work thanks in advance
M
marty01
ireland
Hi tiggy just a bit of help I have put a number of images onto my pen drive throuh flaswizard currently using gemni 2.5 but now when i try to connect it states error 10061 in function connect connection refused can you help thanks in advance
C
coutinhos
P4 3.0 DB7020s whit 250 GB HDD Pansat 2700 REX1
UrS
Hi this is my first post here i live un the US i will post this just to try to help whit the network on the DB7020.After i had all kind off problems myself and after many readings i found this post here:http://www.sat-industry.net/forums/showthread.php?t=25847
Ok after that i went out got those two capacitors for less than 5 dollars and voila never again did i had any problems.I am now able to download movies to the PC at more than 4.o mbts per second..Hope this post will help you people and remember this is for the DB7020 i dont know nothing about the other models..Also as i see here a lot off posts about the Gemini image i can tell you guys that Gemini 2.60 Xmas image been out for the last 2 or 3 weeks thats the image i been using plus a couple more on the flash on HDD and so far thats the best image i ever used no dougth about ..Catch you later
R
radicalrad
Gemini v2.70:
Technical Infos:
* Enigma of: 26.01.2006
* GCC 3.4.4 Original CVS
* Web Interface: 5.9.2-Expert
* Busybox 1.01
* Tuxtxt V1.96
Function Buttons:
* BLUE - Blue Panel (BP)
* 2x BLUE - BP -> Extras/Settings
* YELLOW - Quick-Button (can be configured via BP)
* RED - EPG list for active channel
* 2x RED - EPG style menu
* GREEN - subservices
Features:
* Own Addon-Server via internet.
* AutoCam: Emus can be linked to channel/provider
* Cam-Settings: For example renaming of emus, Multichannel-Patch switchable ( >=7000 )
* OSD: EMM- and ECM- Display switchable
* Downloading and installation of additional features via Internet from Gemini server
* System Info: Many extra box infos (for example harddisk-temperature or all Enigma-settings)
* Download of Gemini News in background
* JPEGs can be rotated and the EXIF-Tags can be displayed ( >=7000 )
* Support for OGG/Vorbis
* Random - function for MP3 and OGG
* Quick-Button-Menu: Many extra features for the yellow button
* smbmount
* Support for CDROM/DVD, no matter if they use a IDE or USB port ( >=7000 )
* Record CIFS/NFS: Record to a CIFS or NFS mounted harddisk (only working if there is no harddisk inside the box,
the Mountpoint set to "/mnt/usb" and at least 3G:cool:
* Extra Menu: Settings for many extras like Inadyn, HTTPD, EPG-Cache, swap-out of "/var" and many more
* Backup function
* Dreamnetcast: with Shoutcast TOP(100)
* Backround pictures for Radio, MP3 and SCAN can be choosen via Blue Panel
* Own scripts can be started via Blue Panel
* Calender including reminder (can be changed via .../gemini_cal.conf)
* MVI's can be converted and tested (from JPG, BMP, GIF or PNG)
* The Bootlogo for 7020 can be changed via menu
* New font and libfribidi for arabian
* EPG for Dishnetwork
* 2 new entries for music and pictures can be created in root of the filemenu (BP->Extras/Settings->Root-Entry)
* Create your own Satellites.xml
* Dreambox can be used as printserver(BP->Extras/Settings->Printer (LPD) FAQ can be found in the database
* Alarm Clock with volume offset adjustable playing your own WAV-files.
New:
* Configfile for calendar changed to XML
Fix:
* Printserver (memory bug)
* Root-Entry of Extras/Settings for boxes < 7020
* Display of new messages
Interfaces WebIF:
_http://127.0.0.1/cgi-bin/GeminiInfo
_http://127.0.0.1/cgi-bin/StopCam?ZAHL (ZAHL = Nummer des Cams)
_http://127.0.0.1/cgi-bin/StartCam?ZAHL (ZAHL = Nummer des Cams)
_http://127.0.0.1/cgi-bin/InitCam
_http://127.0.0.1/cgi-bin/ResetCam
We'd like to thank everybody who paricipated in the "Gemini suggestion" Thread.
Unfortunatly many things can not be realized from our side.
This Images doesn't contain any keys or softcams.
Backups or other modified Images are not from us
and won't be supported!
Recommendation:
If you don't install the Image in flash memory, the flash image shouldn't be of a old version.
A swap file/partition (>= 16M:cool: should be present if several processes running in backround.
Havent seen it posted anywhere so here you go....sorry it wont let me post it.so here is is the info anyway
awai
Hi Can I install Gemini on hraddisk without any risk ?
Dreambox 7020
Cheers
D
dirkster
Dreambox 7020, 1.3m dish on Hotbirds.
Kuwait
Dreambox 7020
Cheers
You already posted this question in the main 7020 thread and while the answer yes was never said directly (yes you can) the reason that it isn't a good idea (hard diive spins constantly) were pointed out. I don't know how long a hard drive motor lasts but if you can stand the noise of the platters spinning constantly there is no reason you can't install to the hard drive that I know of.
D
doos
dm-7020-si
gemini_4.40
emirates
Gemini v4.3:
Technical Infos:
* Enigma of: 16.02.2008
* Web Interface: 6.0.4-Expert
* Busybox 1.01
* Tuxtxt V1.99
* CIFS 1.44
Remotecontrol:
Addons:
* own Addon-Server via Internet
* adding additional functions via internet from the Gemini-Server and install them automaticly
* Personal Addon-Server can be used (configuration via /var/etc/useraddon.xml)
* Create your own Satellites.xml, which only contains the Satellites you realy need
Camd:
* Different Camd�s can be linked to channels/provider (Autocam)
* Changeing the name and settings via own menu.
* Creation of a 2nd socket (/tmp/cam1.socket)
Daemon / Server / Clients:
* Dreambox can be used as printserver (BP->Extras/Settings->Printer (LPD), FAQ can be found in the database
* Dropbear (SSH) now switchable (DM500 - DM7000: Standard->off)
* Upnp Client and Server (for DM500 - DM7000 must be installed from our Gemini-Server)
* Automount, for examples have a look at: /var/etc/automount.conf. Devices, NFS or CIFS will be automatically mounted. Ideally for DVD- or Net- Drives (Editor can be found in the BP)
* Inadyn (Daemon for different DYNDNS-Services)
* little Apache (HTTP-Server based on HTTPD)
* NFS-Server (based on the NFS-Kernel-Modules)
Infobar / OSD / Skin / Background-Pictures:
* Position of the Infobar can be changed without editing the skin files
* Provider, Frequencies, Symbolrate and FEC can be displayed in the Infobar (If the Skins matches this function)
* Display of EMM, ECM or "Expertinfos" are switchable
* Picon (displaying the Channel-Logo)
* Extensions for Skins (Thumbnails, 3D-Font, Pictures for Progressbar)
* Background picture can be turned off (Plasma - Fix)
* Backgroundpictures (Radio- and File Mode) can be used as Screensaver.
* Changing Bootlogo via menu ( 7020 only)
* Backgroundpictures and Bootlogos can be created, testet and used direct on the Box (out of JPG, BMP, GIF or PNG)
* Showing Onlinestatus when the Box is connected to the Internet (must be activated in Expert Menu -> Network)
Files / Devices
* Support for CDROM/DVD no matter using IDE or USB
* JPEG�s ca be rotated and dislaying of the EXIF-Tags (not DM500)
* Random function for MP3 and OGG/Vorbis
* Backup function
* 2 new root entries for music and pictures can be created in the filemenu (BP->Extras/Settings->Root-Entry)
* support for the bigger remotecontrol on 500 and 500+ (normaly shipped with 70XX/600pvr - activate on BP->Extras/Settings)
Extras:
* Dreamnetcast (shoutcast-player) with Streamripper (direct recording from server and coding into mp3�s)
* RSS und Weather Plugin (for 7000 and 500 you have to install it)
* System Info: Many extra box infos like HDD temprature, stream-rates (>=7000) or kernel-, memory- and prozessinfos.
* Own scipts can be started via Blue Panel
* Changing the recording parameters (extra before- and after- recording time, storage location and recover-function for your records)
* Additional EPG-functions (Dishnetwork, cache, storage location)
* Font and Libfribidi e.g. for arabic
* Quick-Button-Menu: Many extra features for the yellow button (e.g permanent clock in OSD, freeze Image, audio selection)
* alarm-clock with volume offset playing own WAV-Files
* Calander for iCalander format + reminder ( Supported by MAC, KDE, Thunderbird, Goole calander, Rainlendar...). Standard folder is /var/etc(ical
* Support for DreamDVD no matter wether a DVD-Drive is available or not
* New screenshot routines (have a look at the Webif)
* Search EPG of all channels for an Event or a String and set timers directly (press MENU in EPG window or go to BP -> Extras)
* EPG-Infos of all recorded movies can be showed without starting the record.
* eTorrent - a torrent client based on ctorrent. Can be managed completly over the OSD
* disable the TV - output while taking a recording, streaming a movie and manually (usefull for boxes with very low lan-speed)
* update system time via transponder or internet ( Protocol RFC868 )
New:
* EPG-Refresh Based on Enigma-Timers (BP->Extras, Beta)
* In the Information menu own matrix for network Devices
* create own weather.xml for your Country in RSS/Weather Addon
* Dreamnetcast now with Favorites administration
Fix + update:
* eMail-Checker und IMAP (Unread e-mails remain unread, problems with GMail)
* Pictures turn lasts only half as long, all formats ca now be rotated (rotate with < 0 > on your Remote Control)
* please see CVS
Interfaces WebIF:
_http://127.0.0.1/cgi-bin/StopCam?ZAHL (ZAHL = number of cam)
_http://127.0.0.1/cgi-bin/StartCam?ZAHL (ZAHL = number of cam)
_http://127.0.0.1/cgi-bin/setKey?typ=STR&key=/elitedvb/str-test&val=blabla
_http://127.0.0.1/cgi-bin/getKey?typ=INT&key=/elitedvb/int-test
We'd like to thank everybody who paricipated in the "Gemini suggestion" thread. Unfortunatly many things can not be realized from our side.
This images doesn't contain any keys or softcams. Backups or other modified Images are not from us and won't be supported!
Recommendation:
If you don't install the Image in flash memory, the flash image shouldn't be of a old version. A swap file/partition (>= 16M:cool: should be present
if several processes running in background.
Thanks a lot and have fun
Your Gemini-Team
dig deep
dig deep
Prince of Birthdays
Dream7020 and AZ Elite and a few DM800
Sweden
Here it is
http://rapidshare.com/files/149131842/gemini-450-dm7020.html
mhku
mhku
TM Nano ~ sg2100
Midlands
Yes. If you're using Gemini don't go later than 4.30
