ASTRA 2D BBC & ITV RECEPTION
psychomet
Intending to set up a satellite installation in Italy
Umbria, Italy
Hi all, new to this forum. Shortly moving to Umbria in Italy (about 25km NE of Perugia). Keen to receive BBC channels etc but been getting conflicting advice about reception possibilities. have read on other bulletin boards that I should get 2D with a 2.4 mtr dish, but an installer in southern umbria says no chance mate. I am not keen to fork out for a large dish only to find I can only get channels I could have got with a 1 mtr dish or whatever.
I have 3 questions:
1. Does anyone have any knowledge of Astra 2D reception in Umbria?
2. Is it feasible to connect 2 smaller dishes (say 1.8 + 1.0 mtr) and sum the outputs in some way?
3. Is it feasible to hire a mobile dish to try it out first?
Psychomet
I have 3 questions:
Psychomet
1) Impossible to say apart from general info - extreme fringe reception isnt an exact science - there are "hot and cold spots" caused by minute imperfections in the reflector surface . Reception can and does vary greatly over a few miles. Local knowledge is always favoured over forum guesswork.
2) No - its possible at radio telescope wavelengths, but unless you want to spend many tens of thousands of Euros its impractical at household level.
3) Only if local installers will hire out their dishes!
m.crewe
fortec 2.4 meter dish Invacom c120 prime focus LNB. Pace sky digibox
Czech
I want The Beeb and ITV to move away from astra 2d reading this site noone is happy there there Spain Italy Czech Rep and the rest of Europe all ex pats wants them to move
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
You are being ridiculous, they never will as they have to minimise reception to the UK for legal reasons.
psychomet
Umbria, Italy
Any suggestions about dish size and the most cost effective dish if it's around 2.4 mtrs (when they get very expensive!)?
Topper
The Beeb ITV & C4 (and soon to be C5) dont care in the slightest if as few hundred thousand expats are inconvenienced.
If our TV is so important to you then move to Blighty or northwestern Europe where its easy to get. :D
gio2010
Visit site
Hi psychomet
I live 20 km south from Perugia and I can receive BB1, BB2, ITV 1 and soome more channels with a 1,80m dish from abot 12 am to 7 pm.
My dish is not in very good contidions, so I suppose with a better and bigger dish things can improve a lot.
A few days ago I bought a Humax foxsat receiver and it works much better than the old Panasonic TU-DSB 30.
psychomet
Umbria, Italy
Thanks Gio2010,
We should definitely stay in touch - email me.
Does anyone know anything about these fibreglass dishes - _www.pellini.org- I have been offered a 2.5mtr dish at a good price.
Thanks Topper, but your archive link doesn't seem to work. I have tried searching on 'Umbria' but nothing comes up.
Topper
psychomet
Umbria, Italy
Thanks for the correct reference Topper.
Apologies for the breach in rules - does anyone know anything about the Pellini dishes?
ll.luca
90 CM disc + different receivers
Italy
I am not sure It can help you,
In my location Nord Tuscany close to Lucca with my disc 90 cm I receive the signal well but during the evening and night Itv3 and Itv2 have some problem.
During my test The quality change depending by the receiver.
I think the sensitivity of the receiver play an important role
Best regards
Luca
ynotdu
sky digibox also U P C Ireland
Ireland
Hi a trick with user installation is to partially cover the dish with a material that will block signal back to L.N.B,even without signal strenth metre It gives the best possible alighment You will ever get from Your dish,also better to install on a really cloudy day.It makes self(but cheap)installation more difficult but totally sets dish at correct place within less than 1cm of absoulute perfect.On Sky box,s under signal test Strenght= left/right. Quality=Up/down,It is strange but signal strenth can be perfect but if signal quality is bad Many channels do not appear or freeze.Many so Called professional installers,are somewhat incompetant or careless,They dont know their Azz imuth from their elbow ! ;-)
Coviello
Potenza (Italy)
Prodelin 11ft (335 cm)
Windows 2000 XP
Southern Italy
Look at the thread 3.7m Prodeline dish for Astra 2D .
Coviello
ralphmagno
naples italy
hi to all
here Astra 2 d is no good even with a 4 meter dish.
but some can with a 1.20 meter dish.
no BBC we tried .
E-4 AT 11,565 V
C 4 AT 12,480 V
ITV AT 12,402 V
itv was on Astra 2 d and had transponder problems and went to Astra 2 c
but went encrypted with sky UK system
this was 2 months ago.
you can put this in the added channels and you must have a sky UK card active.
Ralph
colin gregg
1.2 solid Gibertini dish
Panasonic DSB30
Venice Italy
Does anyone know the size of dish required to pick up BBC in Venice, Italy, or the surrounding Veneto
satelliteman
Reports show around a 150cm - 180cm depending on exact location. Local knowledge is always best.
Montafon Guy
4,5 m Andrew -Multifeed C/Ku Band
Austria
m.crewe said:
[fieldset=Admin] very long quotation removed not relevant to your post[/fieldset]
czech rep jihlava area 2.4 fortec dish zero signal on astra 2d
Ahoj,
im sorry your dish is very bad.
You need a Dish in one Piece like a Prodelin, Andrew, Patriot, Kathrein, Channel Master,....
A Friend receives in Austria ( farer away from the Beam as you ) Astra 2d with 2,3 m Solid Dish! (horizontal nearly everything and vertical with tropouts at 21.00 cet. )
Regards Montafon Guy!
colin gregg
Panasonic DSB30
Venice Italy
thanks guys. i was told 1.2 but I didn't believe that. I always thought it more 1.5-1.8m
deepbluesky
Terratec T-Stick+ (DAB+)
Stuttgart (48.79N/9.19E)
There are some people getting Astra 2D in Venezia on 1.2m but it's on the very limit so indeed not to recommend if you've got space. 1.5m should be fine and 1.8m just ideal. Motorising latter will bring you also some other critical satellites/beams like Thor 5 T1. Just take care choosing high quality. For more information about reception conditions and installations in Italy i'd recommend this board: _http://www.digital-forum.it/forumdisplay.php?f=33
