I got it last year for few days and then returned it problem facedyou cant go wrong with octagon sf8008 - tuner more sensitive than edision mio 4k
for any E2 receiver you can download and use SATFINDER app configured for E2 ip address - i use it up ladder to peak signal in real time over wifi
Maybe it got fixed by new update/softwarenever had that, i have two of them
I doubt it is a resolution issue but try 720p if your TV is some three years old or over.We've had a few people have problems with 4K televisions (LG & Philips IIRC) and E2 receivers. Perhaps an issue with HDR?
Octagon picture get pixelated 2 nudges before xcruiser on 12130A better way to compare sensitivity would be to keep nudging the dish and seeing which receiver's picture starts to break up first. Percentage figures aren't comparable as they mean different things on different receivers.
Try 23.5E 12640V 940 Radio Deutschlandfunk
Assuming you are using an Inverto Black Ultra single, how are the receivers connected,Octagon picture get pixelated 2 nudges before xcruiser on 12130
Yes nudges can be of different size on different receiversAssuming you are using an Inverto Black Ultra single, how are the receivers connected,is the Octagon connected to a loop through from the XCruiser orare you swapping the cables over? If you are swapping the cable over that's a decent improvement.
Are you using just one receiver to nudge or on each receiver separately? One receiver's nudge may be bigger than the other's. Do you receive any extra channels on 26E? Also where can you buy this receiver?
How about 23.5E 12642V 280 Radio Osttirol
