BisTV at Hotbird 13E
Sjohnson
Tivusat Telesystem receiver, 60cm dish, pointed at Hotbird 13e
Kent
Hi all
I have a dish pointed at Hotbird 13E, Tivùsat receiver (Telesystem TS9018) and Tivùsat card and am able to watch Italian TV with no problems.
I would now like to watch some French TV too. The easiest solution to my mind would be to subscribe to BisTV which also broadcasts on Hotbird 13E, so that I would only need one dish pointing in the same direction.
I don't think my current TS9018 receiver is capable of supporting what I'd need for the French set up (CAM CI+?), so should I upgrade receiver, and if so, to what?
Once upgraded, would I be able to flick between French and Italian TV simply by changing the cards over?
Thank you!
EnoSat
enosat.euweb.cz
Slovakia
It is ideal to have a receiver with two CI slot and two CAM modules (BiS + TivuSat).
Or buy a BiS receiver.
Sjohnson
Kent
Thanks! Can you recommend any receivers with two CI and two CAMs?
