Cant open 39east, help!
chucklebezza
39east and 19e when I want to see F1, using a tm1500ci
surrey
Im using the latest keys, the ones starting DF DD etc but it wont open. I have been using Bulsat for the past couple of years so I am used to entering keys but for some reason I cant get it. Has anyone else got this open using these keys? Cheers
martinuk
1.2M Channel Master, C120 Invacom 0.3 LNB & Feedhorn, with Tm.Vbox &Technomate 5402HD
uk-stoke-on-trent
can you open 10e prem leage tv cant find keys any were dont think can be open.
have you tried restart box etc mate
chucklebezza
surrey
Thanks martinuk but Ive got a tm1500, no use for PLTV 10e which as I understand it is hd and Biss keys unavailable, thats why I need to open 39e.
A nonymous
Most of the channels on Bulsat have moved over to Bulcrypt & Griffincrypt mate, including the sports channels.
Theres not a lot left open in Irdeto2, only the basic stuff like discovery & national geographic.
Try putting it on Discovery and see if it clears.
Nano
martinuk
uk-stoke-on-trent
with the tm you need go on the channel there a code tap in gets up keys then enter them i tried do it for 10e pltv but cant get pltv by keys now?
T_G
The Consumate Dreamer
1 GigaBlue Quad plus, 1 Dreambox 5620, MOTECK SG2100A DISEqC Motor, 120 cm noname offset dish, Humax 95 cm offset dish and a few UK digiboxes.
Somewhere where the Sauer is Kraut and the Wurst is Brat
I can see Bulsat on my Qbox using Mgcamd, or you could install Fausto on your computer and then connect to it using cccam.
Not sure about PL on 10 east, I wasn't aware that there is a possibility to watch this with anything.
T_G
Errrrrm actually when I checked I can see Bulsat on my Dream using Mgcamd 1.37. You might want to google
"Mgcamd_1.37 Paket.rar" :)
Plumbob
TRIAX 110 dish,TM2600,TM5402HD...
Samsung BD-DT7800 Freesat
TELFORD
Hi am watching nova sport on a tm5402 hd with soft cam at moment,,, cheers
Chris76
Vu+ duo with a 300gb hdd also dm500 and tecnomate 5200 with a 1m and 1.1m motorized dishes and minidish fixed to 28.2
Belfast
Sounds like you need the latest patch for your TM then input the keys. And it should open
Sent from iPhone using Taptalk.
chucklebezza
surrey
Ive put in the new keys and all up and running including sports channels Diema and Novasport, result!
T_G
Good to hear. Anyone got any luck with PL TVee on 10 east with anything?
wod
yorkshire
not unless someone knows the biss code for it thats if it hasn't gone properly encrypted ?
