Well.....Now what is to prevent the bolt from shearing off that little bit left over??? there is a lot of stress on that part during a high wind condition, and more during the movement of the dish.
its annoying as the motor bracket covers the hole slightly - so when you want to adjust it - you have to loosen off both side bolts to get access, for me this, ruined alignment slightly.
my "hack" gets around having to do this, and turns a 30 min job, more if, it screws up alignment, into a 5 min job.
I have a small number of Dark motors here, not new but complete with little wear.
Tested on full arc and reset to factory conditions with the Emitor analyser. All threads checked, bolts/nuts cleaned and lubed
£23 + a box + whatever courier is needed to get them to you, so expect £30 delivered to mainland UK.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
