db 7020 and hard disc problem
karibu
Dreambox
Greece
Please your help is kindly needed
A few months ago i sent my db 7020 to change the motherboard because the ethernet port was dead and i received it back repared but there is a problem with my hard disk. DB can not record or communicate with the disk.
i have a 200gb disk
connected: master
the status is: initialized, but unknown filesystem
So i did a format on windows because i couldn't do it from the DB
I put it back in the DB but nothis is working now. If i take it out the DB is working ok.
If this can help I have gemini 4.40 and mgcamd
somebody could help me please?
thank you
A nonymous
you will need to format it in the Dreambox mate :D
The DM uses a different file system to windows :mad:
to do it (Under S.I.F 1.9.3 , Should be the same in Gemini)
Menu ->6 then ->3 then ->4
You will then see Hard Disk setup
Press OK and you will see the hdd settings screen (Last piccie)
Press the Red button to format
:-beer
Nano
karibu
Dreambox
Greece
Yes i know I need to make another format on DB. But this is impossible because now the problem is as mentioned above nothing is working when I put the disk inside.
mike1
Non-28.2° Sat Specialist
Yorkshire Television
Triax 64cm triax ( Darkmotor ) Inverto Black Ultra.
T55 - 28E/19E/13E/1.9E
Mutant AX 51 Open PLi
GT Media V7SX
whats that theme called you using can you download of blue pannel :)
A nonymous
Rihanna blue or Rihanna Black, Its one of them :D
Downloadable from blue button on SIF and i also think its available on Nabilosat to, but don't hold me to that :cool:
:-beer
Nano
karibu
Dreambox
Greece
Hey guys thank you fior reply
But sorry I dont understand what is to do.
When i put back the Hard Disk nothing is working...
When the hard disk is not connected the DM is working without it..
What should I do?
Their might be a hardware problem?
Thank you Guys
karibu
Dreambox
Greece
By saying that it is not working I mean the screen is on but without any access to any menu
thank you
newgolfer
Dreambox 7020S
Italy
Format before in Windows with FAT32 not NTFS and after in Dreambox.
karibu
Dreambox
Greece
thank you for your reply
Im not familiar with FAT32
cound you give me clu??
thank you again
karibu
Dreambox
Greece
thank you again
Decoder
Hi karibu If you "g**gle" FAT32 you get loads of options M8.
Best wishes
