Dead Ethernet socket on his box?
wod
yorkshire
Got a Sky hd box amstrad dx780 I think and just noticed that I’m no longer able to connect wirelessly and view planner recordings etc on my phone and tablet through the sky+ app.
It’s connected to sky hub box thing by Ethernet cable and it won’t work anymore.
Tried rebooting the Sky hub and spare Ethernet cables etc but nothing.
Only thing not tried is a full system reset as I’ve got recordings on there to watch, even the network reset doesn’t work in the software settings.
Dead Ethernet socket on sky box?
Anything else I could try
Cheers
Archive-8
Got a Sky hd box and just noticed that I’m no longer able to connect wirelessly and view planner recordings etc on my phone and tablet through the sky+ app.
Cheers
Have you checked the Ethernet cable is fully home? As the little plastic lug can break off and the cable doesn’t then seat fully home.
wod
yorkshire
Have you checked the Ethernet cable is fully home? As the little plastic lug can brake off and the cable doesn’t then seat fully home.
Checked this there’s the two blicking green/yellow lights on the router Ethernet socket with the cable plugged in but nothing on receiver side all cables connected correctly.
It was working a couple of days ago until the sky+ app couldn’t see the sky planner anymore on my receiver.
Check you dont have any ip address clashes - if the Sky+ ip has got assigned to another device on the router by mistake it will kill the connectivity.
Terryl
Custom built PC
It kind of rare for a LAN port to go dead by it's self, was there any type of power surge, electrical storm or electrical service failure at that time???
Anything new added to the WIFI, router or LAN system???
How close is the nearest neighbor??? They could have a new device installed and it's conflicting with your WIFI.
Have you reset the receiver as well?? Fully - pull the plug out of the wall wait for 30 seconds then plug it back in and let it reinitialise.
wod
yorkshire
Hmm I’ll have to check that I’m sure dhcp is enabled on the router, it’s a Sky one you get given so doubt it’s going to be configured for static ips
I’ve tried that but will leave it longer this time.
Cheers for the help people:)
wod
yorkshire
Nothing new just a PS4, tablet and mobile connected.
Only just happened a couple of days ago.
If you have a computer bring up the command prompt (type cmd in the run box)
then type
ping numerical ipaddress of device then hit enter
if you get 100% packet loss then you arent seeing the device on the network.
So if the Sky box has the ip of 192.168.1.41 you type
ping 192.168.1.41
FWIW, assuming it's a Windows OS PC, then go to "Devices and printers" and that may show it, as might going to "Control Panel" , "Networks and Sharing", "View your network information and setup", "your" SSID name".
If that doesn't work then you should find out how to log into the hub/router and see which devices it can "see" on the network. If that doesn't work then you need to find a PC command line utility that will scan the whole network to see what is on it (I have one but I can't remember what it is ATM!).
If none of those show the Sky box, that would tend to confirm that that the port on the box is indeed dead! - OTOH, I've never had that happen either (with multiple boxes of various generations).
wod
yorkshire
Cheers for the further help guys.
I’ve unplugged the receiver two times last night left for about ten minutes and must have reset it, network features back online.
Hope it’s not on the way out.
Usually a router reboot does the trick didn’t this time.
Update to Post #10:
The free utility I was thinking of is "Advanced IP Scanner" - my Sky+HD box (DRX895) shows up as 192.168.1.16 and is connected to the router via 3x Gigabyte Ethernet switches, and the router and all the mobiles, tablets and other PC's currently "on" the network show up as well.
PS: Was wrong to say (from memory) that it is a command-line utility - it's actually run as a Windows App
