Dreambox network problem
D
Dreambox.
Dreambox 7020
Netgear Wndr 3700
malmö
Hello
I have a dreambox 7020 and i have a netgear wndr3700.
Then i connect my dreambox with the wndr3700 the network didn´t work and the netgear wndr3700 don´t (light blink )
What i have to do?
My Dreambox work with other Device.
what did i have to do with my netgear?
J
J700
moteck sg2100a rotor. 1,3m dish. Invacom lnb. ipbox 900hd. 1,5TB eSATA hdd.
Scandinavia 63N 21E
Try crossover cable if using straight cable. Try straight cable if using crossover cable.
The dreambox does not have autosensing.
If that does not help do the network modification as described in dreambox wiki
_h**p://dreambox.wikia.com/wiki/Increase_Network_Speed
BM300
BM300
Dreambox 7000, 7020, 800HD
HD-USB
8 Dishes
UAE
Try conecting an 8 or 4 port switch between the dreambox and the wndr3700 using a straight LAN cable.
L
LowNoiseBloke
S.Staffs., U.K.
Force Frontier 90,2xEmp-Centauri P168(28.2,23.5,19.2,16,13,9,5E,5W)
Vu+Duo2 & Now TV, Amazon Fire TV & Droidbox X7,
Buffalo Linkstation,
Pace TDS850NB Sky+HD,
Ubuntu/Fedora servers,
Technisat AirStar/Freeview.
South Staffs. U.K.
The WNDR3700 has a built in switch - it's a router. The first thing to check is that the DM7020 and the wndr3700 are in the same network domain. Looking at the manual for the router the default i/p address appears to be 192.168.1.1. The usual default i/p for a Dreambox is 192.168.0.24. One or other of these devices probably has to have its i/p address redefined to bring both addresses into the same domain either 192.168.1.x or 192.168.0.x. A standard cat5 cable should be OK.
