Edision piccollo combi streaming help?
astra19
33cm camping dish on a bucket on the balcony. Signals received from: 42e, 39e, 33e, 28.2e, 19.2e, 13e, 9e, 7e, 5e, 1w, 5w, 14w, 30w, 35w, 40.5w
London
Hi all,
I got myself an Edision DVB-S2/C/T2 receiver and I'm pretty happy with it so far. However, I can't seem to get streaming working. In my browser I can type in the IP address of the box and I can control it using my computer, but the console for Sat2Ip is so old that no browsers support the plugin that it's using so I can't actually see a picture. And even though my browser (and my router) recognises the box is on the network, VLC and other media players don't recognise it either automatically or manually. I'm on a wired connection. Can anybody help?
Try this sequence - from another Edison.
astra19
London
That is unfortunately the guide I was using. Nothing seems to recognise the device on the network (other than the router), even though I am able to control it using any device by typing in the IP address into the browser. I'm not sure how I can do one without the other. I wondered if it was to with being plugged directly into the router over plugging into a bus which I use but that doesn't seem to affect it.
I may be getting a Piccollo to play with early next week for a client, so hold on in there. Of course somebody else might pop in before then.
astra19
London
Look forward to it! Thanks for replying quickly. Scratching my head here. Not a major feature of course.
In the meantime you could run a long HDMI cable to the remote point. Many outlets now sell a 30/50 m run at a very reasonable price.
Do any Edision receivers work properly?
LeBelge
LeBelge
2x Triax TD 110, Edision OS Mio 4K, Edision Primo, Vu+ Zero
Belguim
astra19
London
Yes, the mine Edision OS Mio does !
Did you have to do any changes to settings? I’m not sure how to configure things. Or rather, is there a way to parse the playlist url? I’m confused at how all my devices can reach the STB on the network but can’t stream or open it in any media player.
LeBelge
LeBelge
Belguim
