Edision Primo IP S2 - Stream to VLC PC - How To (Possibly Mac & Linux too?)
RustySpoons
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Glad it's all working guys!
I used the programme's inbuit update checker and it told me 3.0.0 was the latest ... prompted by @scopus Post above, I've now also got 3.0.2
Yes, I think they need to sort that!!!
P
Pierangelo
150 cm from 80 east to 40 west + C lnb
Italy
In my clone, u2c denys, It works too, but if I try to change channels, pixels start going Mad....
Tout Rond Bon Oeuf
No Channel change problems at all for the Primo :Y
Another neat trick, you can listen to a radio channel on the TV then stream a TV channnel to VLC all at the same time as long as they are on the same transponder.
Tout Rond Bon Oeuf
For 50 sovs, this is good kit :cool:
stel883_
stel883_
"34.5W-70.5E - Gibertini OP125L, Actuator 18" Superjack 3618, Moteck Vbox2, IBU Quad" "45W-70.5E - Gibertini OP100L, Moteck SG2100A, IBU Single" "Amiko SHD-8360, Edision Primo IP S2, Axas E4HD Combo, Edision OS Mini 4k" "Tivusat Gold Card - Oscam" "Toshiba 32L3963DG"
"Fujitsu Lifebook S752 - Windows 10 64-bit"
Vátika, Greece
I have set up streaming too, updated vlc and all is good!! Thanks to all :)
stel883_
stel883_
Vátika, Greece
Updated vlc from 3.0.2 64-bit to version 3.0.3 64-bit, and streaming wouldn't work properly, so went back to 3.0.0 64-bit.
LeBelge
LeBelge
2x Triax TD 110, Edision OS Mio 4K, Edision Primo, Vu+ Zero
Belguim
Another way to easily test thе streaming from Primo is to use a Live DVD ( or USB flash stick) and boot from it.
I did it with PCLinuxOS KDE and it works fine without installation.
By choosing the option "Copy to RAM", when Linux is ready VLC 3.0.3 is already in the menu.
During the test, the power supply to the computer's hard drive was stopped.
4x zone 2, 3x channel master 90cm, 1x channel master 1.2m
I've got streaming working via VLC where the channel chosen on the VLC playlist. Is it possible to have VLC continuously stream whatever is being viewed on the Primo and use the remote to change channels? Is that possible on any receiver?
I use VLC to squish the video to 32:9 and align it to the top of the frame (so it's like top and bottom 3D, but the bottom half is black), then on the connected TV select manual 3D top and bottom and voila, motion clarity is vastly improved at the expense of brightness. This works on any active 3D TV (battery powered glasses). On an LCD/LED it reduces the persistence by half, like a black frame insertion mode. On a 3D plasma it makes it a true 50hz display and not double scan 100hz, looks superb but having to use VLC to change the channel is clunky.
