Just Sharing This Glamour Aura FHD skin - first public release candidate (RC3)
MCelliotG
Thessaloniki, Greece
With great pleasure, I finally present publicly my latest project, which is none other than my new skin called Glamour Aura FHD. It's a labor of more than a year in the making and testing!
Glamour Aura FHD (GAFHD) is a Full High Definition and High graphic resolution skin for receivers running Enigma2 and the recent OpenPLI/OpenPLI-based images.
Due to its high resolution graphical nature, GAFHD was designed and optimized to run on new generation receivers. The minimal requirement is an STB with a CPU of 750 Mhz (2000 DMIPS).
GAFHD is also a skin you can contribute to. The ipk of the skin is distributed with closed converters/renderers, but all the python code along with the skin code is available on Github.
You can find the source code here: https://github.com/MCelliotG/GlamourAuraFHD-skin
You can pull your requests, make recipes for it and I will push contributions after testing.
GAFHD on par with its graphical user interface is fortified with an extended python system that runs along with OpenPLI's enviroment, providing it with some exclusive new features.
SCREENSHOTS and extended features presentation
1. Main Infobar
The main infobar is divided into two sections. The top section contains all frequency and signal info. GAFHD is the first skin that fully supports real-time info for Multistream services, showing MIS info when such a service is tuned. Up to 12 tuners can also be displayed. The left top part is a weather panel which shows today's weather. Weather info requires the MSN weather plugin to be installed and configured (instructions will follow).
The top infobar will also display full stream URL and stream type when a service is stream.
The lower section is the main infobar which contains along with the program info, an extended service info icons panel, including icons for audio/video codecs, a full exact framerate display, and a short weather panel which shows the current weather condition. GAFHD can also display a live bitrate if the bitrate plugin is installed and configured (this will be explained below as well).
The lowest part of the main infobar is the extended encryption info. GAFHD uses a new detection feature which shows all available caids and encryption system names of a service.
NOTE: The skin works best with 400X240 picon size.
2. Second infobar
The second infobar brings an amplitude of extra information for both the service and the system layout. The weather panel shows additional info on tomorrows weather.
The left panel is the layout info showing real time CPU work, temperature, speed and load and internal HDD temperature. The upper layers show the pids of the service in decimal format and also real time info on connected storage devices, memory and swap.The middle part displays now and next program extended description.
3. Channel selection screens
Channel selection along with the service list on the right displays the extended program description on the left, the five following events and also a new transponder info panel which also shows the stream type and stream url on a stream service and transponder info for the rest.
4. Media player infobar
Media player will additionally show icons for resolution, audio/video codecs, subtitle availability and the exact framerate of a video or stream.
5. Info screen
Info screen along with the usual info also displays the HDD storage panel, which shows connected devices space both internal and network HDD and USB. The storage panel is also available on the HDD screens.
6. Language selection
GAFHD is a truly multilingual skin. It utilizes the new Aura new font I created based on Roboto and Noto fonts the skin is able to show Greek, Cyrillic, Arabic and Georgian among others. More alphabets can be added by request.
INSTRUCTIONS:
1)
Download the ipk of the file. Send the file to /tmp your receiver using an FTP program. Then you can install it manually via telnet or via the software manager.
Manually:
opkg install /tmp/enigma2-plugin-skins-glamouraurafhd_RC.3_all.ipk
2) FOR BITRATE INFO
The bitrate plugin is essential for bitrate to work. You can download it from the plugins menu. For correct display in the skin it needs to be configured as follows:
mode: as infobar,
style skin: compact,
background window: transparent-black,
X screen position: 1645,
Y screen position: 0837,
Z screen position: 14.
The correct settings are also shown in the screencap below:
3) FOR WEATHER INFO
The weather info requires the msn weather plugin to be installed. I have included the ipk as well. After installation you can configure your location via its settings menu.
Download MSN weather plugin from here: MEGA
NOTE: For IPTV streams serviceapp is highly recommended with this skin.
IMPORTANT NOTE:
As stated above, GAFHD is designed to work well ONLY for receivers with a CPU higher than 750Mhz. This is an obligatory limitation due to the high resolution graphical nature of the skin which also makes the package large in size. For receivers with slower CPUs use at your own risk! Also, GAFHD for the moment will not work on any other images (such as OE-A) than OpenPLI and OpenPLI-based images (like SatDreamGr, etc).
DOWNLOAD THE GAFHD SKIN IPK HERE:
MEGA
I want to personally thank my beta testers for their feedback. I encourage developers to contribute to the skin's further development in github.
I really hope you enjoy my work.
MCelliotG
Two videos showing the usage of the skin in real time (SF 4008 receiver)!
1. ATSC and American C and Ku band satellite usage
2. Multistream and 4K in Europe
cardiff
Brittany
Laminas As 1800, multifocus 14 LNB
France
Hello MCelliotG,
On my Octagon SF4008 (openatv 6.1 image) That's what only appears??? or only works on SatDreamGr image.
Cardiff
MCelliotG
Hi Cardiff. It has not been modded for OpenATV yet, it's in my future plans. Only OpenPLI for the moment!
I clearly state it as well above, look:
MCelliotG
GLAMOUR AURA FHD version RC.4
- fixed crash and compatibility in OpenPLI 4.0 images, please try and report
MEGA
tompouce
1.2 M Channel Master motorized+ Gibertini 150 C-band fixed + TBS 5925/6983+ Octagon SF4008
Belgium
Hello MCelliotG,
Happy with your glamour, all's perfect !!
Great job, thanks
lordgothic
Vu+ Solo 4K (SatdreamGR 5)
Edision Primo IP S2
Engel RS8100HD
4.8E + 9E + 13E + 16E + 19.2E + 23.5E + 25.5E + 26.0E + 28.2E + 0.8W + 7.0W + 8.0W + 14.0W + 15.0W + 30.0W (2x120cm dishes, 3x80cm dishes, 1x100cm dish)
Samsung UE65KU6400
Spain
the very best for enigma 2
great job McelliotG ast i told you! i dont want any other skin
MCelliotG
Thank you very much. Hopefully the new version will be ready this weekend. Stay tuned!
MCelliotG
GLAMOUR AURA FHD for OpenPLI update 10/6/2018
- Major changes in coding, optimized for OpenPLI 6.2
- New button and switch pixmaps added
- New screens added
- All develop changes updated
GlamourAuraFHD now supports two versions
The develop version for OpenPLI 6.2/develop and SatDreamGr images
Version B.5
MEGA
The older OpenPLI 6.1 version for older OpenPLI images with old button style
Version A.9
MEGA
Make sure to choose the correct version for your image.
MCelliotG
GLAMOUR AURA FHD for OpenPLI images version B.16 update 25/7/2018
- Added picon support for provider in ChannelSelection.
The naming of the picon is the same as snr picons. For instance AFN (9.0E) should be named afn90e etc.
- Improved system speed and stability
- Added new timer icons
Download here:
For OpenPLI 6.2, develop and SatDreamGr images
MEGA
For OpenPLI 6.1 and older images
MEGA
Congratulations on your success and appreciate your efforts :-clapBecause I know you are also interested in the Dreambox reception,I hope that in your skin we can find especially Blindscan and other informations related to the reception regardless of the installed image.
All developers invest their intelligence more the media side of the receiver and less for the reception.Now that the last tuners that Dreambox comes up with are somewhat more efficient, an increased attention in this direction would satisfy even the enthusiasts.By the way of tuner Silab,here DM920 can lock the signal with low symbol rates,which before,to my knowledge,could not.
I know the performance of a tuner depends first of all on the producer's driver but I think developers can also contribute to this.
Here are a few examples of low symbol rate locked.Perhaps it encourages developers to include in their images many reception features.
Regards :Y
MCelliotG
GLAMOUR AURA FHD skin v.B.24 for OpenPLI develop and SatDreamGr images (update 25/9/2018)
- Added new converter GlamourTuners, only the available installed tuners will now show
- Added support for displaying up to 24 tuners (if ever available)!!!
- Graphic rearrangements in the infobar
- Fixed not found error when hddtemp binary is missing
- Several cosmetic fixes and improvements
- Added new VirtualKeyboard layout support (SDG and develop images ftm)
Download here (version B.24 updated 25/9/2018):
MEGA
It is highly recommended that you remove the previous version first if already installed.
deepbluesky
Terratec T-Stick+ (DAB+)
Stuttgart (48.79N/9.19E)
After a long time finally I could spend some time installing the latest GAFHD skin.
I like it very much but I've found two problems so far on my Octagon SF4008 running the latest SDG 6:
1. Bitrate on Radio Mode always showing N/A
2. After switching to TV Mode green screen and restart of E²
Could you fix it ?
MCelliotG
The radio green screen is an Enigma2 issue.
If you look at the crashlog, you will see that it contains no reference to my skin or any skin. Just try it with another one and you will see the problem persists.
Radio bitrate is for now inactive as the bitrate plugin I use does not currently support standalone values. If a fix for that is ever applied it will work without any change.
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
Could you fix it ?
It would help a great deal if you could post the crash log that was generated during the green screen. Thanks.
deepbluesky
Hello again.
Here is the crash log.
But how can it be an E² issue if it is working before the install of the GAFHD skin ?
At least this was the case after a fresh install of SDG 6.
  • enigma2_crash_1542237169.zip
I think Open ATV broke your SNR reading, shows 100% for every channel, and unable to set it back to dB..on the SF8008SNR.jpg
deepbluesky
I am not using Open ATV but SatDreamgr (SDG in short) and it is not about Audio bitrate in TV stations but in Radio stations.
MCelliotG
@deepbluesky
../../git/lib/gui/ewidget.cpp:337 ASSERTION t FAILED!
because this is an Enigma2 issue, not a skin issue.
I'm aware of this green screen, it's not new. And it happens with every skin. One workaround is to set hide channel list in radio mode to on. You will miss my fabulous radio screen though. The problem is reproduced when you exit the radio screen to the TV channels (and zap to a new TV channel).
@scopus
The new drivers broke SNR in db in DVB-S/S2 in all SF8008, not working on any skin too. It has been reported, but they don't want to accept the issue. Instead they fixed DVB-T/C SNRdb.
MCelliotG
Update: I found the problem (not skin related, but I will make a workaround). So expect an update after this weekend (currently I have a very busy week).
