Manikm909
Small'ish Dish Man
- Sep 10, 2020
- Age
- 47
- Channel Master 1.8M on Edision MIO 4K & GTMEDIA Combo, and CM1.2M on Octagon SF8008
- Kent, UK
hey guys,
as you know last week i setup my new laminas 1.2 - i set it up quickly as the weather was bad....but i was tracking the arc, and knew i needed to fine tune
today was fine tune day.
i got some interesting results....so, 1w is my setup sat - so made sure i was gettin 92% signal on that.
then i checked extreme ends of arc, so i checked, and i could go from 34.5w to 52e - both ends 98% on most TPs - HOWEVER, on the 13e and 19e im getting lower than expected signals...like 65% 70% on RAI and RTL respectively.
i checked nothing was blocking, so i tried manually seeing what i could get on 19e, and manually it went up to 89% -91%....
i dont get how i can get strong signal in middle, and both ends of ARC but what should be strong signals aren't so much....could it be the LNB? im using a Inverto Black Ultra - any known issues with that LNB???
thanks all!
thanks all!
