HDR problem gigablue
Messipsa
Astra 19.2
France
When I run an HDR channel on ASTRA, the tv Detects the HDR signal but the image Becomes dark, what do you think ? I use teamblue 6.4, ue 4k thanx à lot
Which satellite and channel?
Messipsa
Astra 19.2
France
On astra 19e, hdr channels like : UHD1 by ASTRA and SES UHD Demo
UHD1 encrypts in the evening. Have you updated the drivers?
Messipsa
Astra 19.2
France
I Just updated teamblue image, how updated drivers ?
Sorry I don't know as I'm not familiar with the receiver. On another forum someone reported success after contacting Gigablue support:
https://www.opena.tv/gigablue-ue-4k/49859-hdr-hlg-wirking.html
Manikm909
Small'ish Dish Man
Kent, UK
r u sure its the image that goes dark, or just the GUI \ gfx which might make it look like the picture has gone darker... > i've seen that with my Edision \ ZGemma, and Octagon
Messipsa
Astra 19.2
France
Yes im sure, because i played thoses channels with the philips tv and it works very well, do u know how install thé New drivers for gigablue ue 4k ?
Manikm909
Small'ish Dish Man
Kent, UK
drivers will be in the latest image of your choice, you could try more than one image, to see if same thing happens.
dmaavrigdo
1.2m Laminas OFC1200 dish
Inverto Quad Black Ultra IDLT-QDL412-ULTRA-OPN
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
It's because blacks actually show as black and you are not used to it.
Is the TV displaying anything or is it just showing black? Does the TV have separate settings for HDR?
Messipsa
Astra 19.2
France
No, i know hdr , because i played thoses channels with the philips tv and it works very well, and the image it's not really blach but it's pale
Messipsa
Astra 19.2
France
Yes i've all picture, but it's a little pale, in the tv internal receiver, the HDR works but not with GB 4k, and unfortunatly, philips tv don't have settings to deactivate hdr
Are the television's internal satellite tuner and the HDMI input using the same picture settings?
Manikm909
Small'ish Dish Man
Kent, UK
do all\other UHD channels do it, QVC 4K and QVC2 4K - is it 4K or HDR that does it.
Messipsa
Astra 19.2
France
No only hdr channels, qvc 4k works very well, i think that gigablue has solved problem but i don't know what i have to do
Manikm909
Small'ish Dish Man
Kent, UK
as mentioned before, r u on the latest image? have u tried another image yet? worth doing \ checking
Messipsa
Astra 19.2
France
Im with the latest teamblue 6.4 image, no i didn't tried another image
Manikm909
Small'ish Dish Man
Kent, UK
Worth trying a different image mate. Can u install into another slot for a quick test
