saygi
- Jan 15, 2010
- Age
- 43
Dreambox 600-S
Windows 7 x64
- United Kingdom
Hi, every one. how are you.
I got my dreambox 600 delivered to UK today from atendo.de
I've been using technomate, as a receiver for long time and I had no problem with it.
Here's my Settings from technomate recever:
- Satellite Setup -
LNB Power: ON
LNB Type: Universal
LNB Freq: 9.750 / 10.600
22Khz: AUTO
DISEqc 1.0: OFF
DISEqc 1.1: OFF
- Motor Setup -
Satellite: 42.0E Turksat 1C
Transponder: 12.652(H)/22500
DISEqc Motor: 1.2
and here's my setting for the DM600:
- Motor Config Page1 -
Unchecked Use gotoXX Function
Number In Motor: 1
Orbital Position: 420
Direction: East
- Motor Config Page2 -
Mode: Position
Satellite: Turk-/Eurasiasat
Transponder: 11920 V 24440
SNR: 64%
AGC: 77
- LNB Configuration Page 1-
Set/LNB mapping: LNB0
LOF/L: 11300
LOF/H: 11300
Threshold: 11700
Increased voltage (UNCHECKED)
- LNB Configuration Page 2-
Toneburst: None
DESEqc Mode: Version 1.2
DISEqc Parameter: A/A
DISEqc Repeats: None
Unxommited Switch: None
Squence repeat + Fast DISEqc and Swap Commands (UNCHECKED)
- Satellite Configuration -
non-standard user defined configuration...
Sat/Position: Turk-/Eurasiasat
LNB: 0
22Khz HI/Lo
Voltage: H/V
I did not setup technomate myself it was done by the engineer, so i played with setting on DM600 I get signal but when I do a channel scan it does not find anything.
please help.
- Satellite Setup -
LNB Power: ON
LNB Type: Universal
22Khz: AUTO
DISEqc 1.0: OFF
DISEqc 1.1: OFF
- Motor Setup -
DISEqc Motor: 1.2
Number In Motor: 1
Direction: East
Mode: Position
SNR: 64%
AGC: 77
LOF/L: 11300
LOF/H: 11300
Threshold: 11700
Toneburst: None
LNB: 0
22Khz HI/Lo
Voltage: H/V
please help.
