Help Required How many lnbs is possible to put in dishes
gaulez
Kaon KSC 570 and Ouralis evo 3 with Metronic motor and sat.dish metronic 80 cm with lnb televes 0,5 db
portugal
Hello.My question is how many lnbs is possible to put in 80cm dish,and the same question for 90cm and 120cm dishes,thank you for helping,I'm waiting for an answer.Best regards.
davemurgtroyd
Oxford
Oxford
It depends a lot on the separation between the satellites you are trying to receive, whether the satelllites can be received on the size of dish used (remember offset lnbs will have a significantly lower signal) and the lnbs you use.
Which satellites are you looking to receive i.e. what part of the satellite arc?
What is your location?
Terryl
Custom built PC
If your trying for more then 3 satellites it would be better to use an elliptical** dish, you would have better signal strength on the outside LNB's.
**An elliptical dish is a bit wider side to side then a normal parabolic dish, this way you can use a multi LNB bracket to add LNB's.
Look at a Dish 1000 setup (used in the US) it can receive 3 satellites at a 19 degree spread, I don't know if you can find one outside of the US or Canada, but there are other makes out there.
Piltdownpaul
No.1 Spike Milligan Fan
At one time i had 10 narrow invertos on a TD88, there was some juggling to work out the best position for pointing the dish in the first instance. Have Turksat satellite at 42 on the far end of a line of LNBs was fine for me at the time as the signals were incredibly strong here in the mdlands.....
gaulez
portugal
Hello everybody.I think to put Hotbird 13E+Astra3B23,5E+ Astra2B28,5E in first dish,and Eutelsat9B9E + Astra1 19,2E+Badr 26E in the other,tell me what size is necessary and it is possible? My location is Lisbon,Portugal.Thanks for yours posts,and for your help.Best regards.
On a 1m dish the minimum seperation you can get is about 4 degrees. It will be a bit less for bigger dishes, & a bit more for smaller dishes.
