Howto get my QboxHD to work using Viasat card?
bruger
QboxHD, Enigma 2, DVB S2 and DVBT
Denmark
I have a QboxHD, Enigma 2
I have installed the following plugins on the box:
mbox 0.5 B21
mbox-newcs
Mgcamd1.35
RaDaR 3.3
I want to get my Viasat NDS card to work on the box and have used telnet to look in som of the config / xml files for radar and newcs
Can you please help me, where i shal put my CardId and BoxID in. and how those plugins i have to use, so i can watch my sat programs on the box.
Is there extra plugins i have to install? and is there a good newbee tutorial in this forum already, on my low level of linux/sat knowledge?
I hope you have the time to help a newbee like me. thx...
T_G
The Consumate Dreamer
1 GigaBlue Quad plus, 1 Dreambox 5620, MOTECK SG2100A DISEqC Motor, 120 cm noname offset dish, Humax 95 cm offset dish and a few UK digiboxes.
Somewhere where the Sauer is Kraut and the Wurst is Brat
What image did you put on ? Did you download the software panel?
Have you got an FTP program set up so you can change the config files?
bruger
Denmark
I have put this image on the box: "Roy Image Bkp QBOXHD 12.2.2010"
I have used telnet to log on, to write in the config files: radar.cfg and newcs.xml
There was a qboxhd softcam panel V2.0.0 included in the image, where i can se mbox, newcs, mgcamd, RaDaR.
when I have my NDS card in the the smartcard reader, RaDaR can "see" the card.
Can you tell me the next steps I have to do, and how to do it.
bruger
Denmark
Is it possible to use the built-in smart card reader, to decode with, or is it a requirement to have a cam module inserted into one of the PCMCIA ports?
superglud
qboxhd 1W 5E 19E
Dell Dimension 9200
Copenhagen Denmark
Hi
I also live in Denmark, and have not yet, my viasat up and running, on my QboxHD
Have you solved your Viasat problem ?
If so, could you then help me
Best Regards
Superglud
