(Info & Firm's) He@d SD 790, 2500, 3900
big9
big9
head 500 fte premium p/hispa
head sd 790 p/astra hotbird hispasat
clã dos mouros
esse firm é igual ao v178 e na serie sd não existe a função 7+info default,e estes firms tiveram morte na praia para os anunciados au´s.
V
vsilva
He@d SD 3900
Germany
Confirmado! Antes dos jogos foi-se tudo abaixo. AU na Premiere nao rola mais!
Por enquanto!
big9
big9
clã dos mouros
sd790fta_01_12_2007.zip
OrF, TpS AU, D+ AU, Other AU enjoy
V180
after sending the firmware send the latest keycode
thanks to gloorija
_http://www.sendspace.com/file/j9ykup
Poison
Poison
He@d 500
بلدي اميرة القلب
Firmware para o He@d serie SDxxxx (Black Panter)
for TPS AU,SRG AU,,*Other enjoy*
...by Team Head International
SD790 - Firmware V303 With PIP Funtion - 01/12/2007
_http://www.mediafire.com/?4tj0erz4z4u
SD2500 - Firmware V0180 - 01/12/2007
_http://www.mediafire.com/?b0n4zvkx03i
SD3900 - Firmware V0180 - 01/12/2007
_http://www.mediafire.com/?5wm3a4ybbuj
SD7200 - Firmware V180 - 01/12/2007
_http://www.mediafire.com/?5gs0jvqejbo
Nota: Apenas para os SD BLACK PANTER
big9
big9
clã dos mouros
Firmware V0184 - 1/01/2008
for TPS AU,SRG AU,PREMIERE AU,POLSAT AU*Other enjoy*
...by team head international
SD790-TESTED OK
_http://www.sendspace.com/file/ta6ter
SD2500-NOT TESTED
_http://www.sendspace.com/file/9y1usd
SD3900-NOT TESTED
_http://www.sendspace.com/file/p21bac
SD7200-NOT TESTED
_http://www.sendspace.com/file/qptuu3
after sending the firmware send the lateste softcam(by big9 & team head.pt) so you can upgrade some providers.don´t forget to open a new topic if you have anything to say about this new firmware.happy new year.big9
ps-this post can be posted on other foruns but please respect is authors,thanks.
big9
big9
clã dos mouros
Firmware para o He@d serie SD BLACK PANTHER
Firmware V0306 - 1/01/2008
SD790 BLACK PANTHER-NOT TESTED
_http://www.sendspace.com/file/0esdut
SD2700 BLACK PANTHER-NOT TESTED
_http://www.sendspace.com/file/n1ts6b
SD7200 BLACK PANTHER-NOT TESTED
_http://www.sendspace.com/file/p3yep4
big9
big9
clã dos mouros
Firmware V0187 - 4/02/2008
for TPS AU(back in action),SRG AU,PREMIERE AU,POLSAT AU(confirmed at last minute)*Other enjoy*
SD790-TESTED OK
_http://www.sendspace.com/file/xis28i
TPS tested working just fine with no freezes.don´t forget to open a new topic if you have anything to say about this new firmware.big9
big9
big9
clã dos mouros
for TPS AU(back again),SRG AU,PREMIERE AU,POLSAT AU(confirmed at last minute)*Other enjoy*
SD790-TESTED OK
SD2500-TESTED OK
_http://www.sendspace.com/file/p92png
SD3900-TESTED OK
_http://www.sendspace.com/file/gvjpzd
SD7200-TESTED OK
_http://www.sendspace.com/file/fn2gf0
atauanna04
atauanna04
HE@D 500 FTA
Italy
Is firmware V0187 correct for SD790FTA Black Panther?
If no, there is an update for version 0306 released?
Thanks.
big9
big9
clã dos mouros
ok let me try to explain to you.theres 2 series of head´s the hd (the old one) and sd (the new ones) and over sd there´s the normal model and the black panther.you can not put the firmware for the normal on the bp version and etç.and tha i now of the latest version for bp is v0307 but only for sd bp 2700 and sd bp7200 for sd bp 790 it´s still the v0306,i hope the this will help you,if you still have any doubt´s just ask,ok.
ddsb
ddsb
..Team.He@d.pt
HE@d HD500 FTA Premium
..Team.He@d.pt
Portugal
big9
big9
clã dos mouros
Firmware para o He@d serie SDxxxx e blackpanther
Firmware V0189 - 14/02/2008
SD790-TESTED OK
_http://www.sendspace.com/file/xt78fd
SD2500-NOT TESTED
_http://www.sendspace.com/file/zy7lrn
SD3900-NOT TESTED
_http://www.sendspace.com/file/jpj64k
on black panther Firmware V0307 - 16/02/2008
He@d_PH_SD790BP_V0307
_http://w14.easy-share.com/1699599513.html
He@d_PH_SD2700BP_V0307
_http://w13.easy-share.com/1699599519.html
after sending the firmware send the lateste softcam(by big9 & team head.pt) so you can upgrade some providers.don´t forget to open a new topic if you have anything to say about this new firmware.pay attention that some sofcams can make some autorrols to stop working.big9 firm especial para os amigos do jardim digital que se fartam de trabalhar.
ddsb
ddsb
..Team.He@d.pt
..Team.He@d.pt
Portugal
Firmware V0189 - 19/02/2008
MCT AU/ TPS AU /Mul. AU/ POlsat AU, enjoy Other AU,
SD790
_http://www.mediafire.com/?bmzq1yket0m
SD2500
_http://www.mediafire.com/?c2emwt0stdm
SD3900
_http://www.mediafire.com/?fxc1ujlnykw
Serie SD BP (V0307)
SD790
_http://www.mediafire.com/?232gycdmjin
SD2700
_http://www.mediafire.com/?bxyccg9dizt
V
vsilva
He@d SD 3900
Germany
20080225_PH_SD790BP_V0310.zip
Emu-Firmware para Black Panther SD790.
Dizem que Pr*miere Sport (PW Sport) funciona. nao tenho esse receptor. Quem quiser testar.....
http://w*w.sendspace.com/file/6ai0so
big9
big9
clã dos mouros
Firmware V0193 - 12/03/2008
SD790-TESTED OK
_http://www.sendspace.com/file/bju3c5
SD2500
_http://www.sendspace.com/file/vavk65
SD3900
_http://www.sendspace.com/file/yrsmru
SD7200
_http://www.sendspace.com/file/o5be4h
Para info e comentários e perguntas á cerca do firm abram um outro topico na secção geral pf.Atenção alguns keycodes(softcams)podem anular os autorrols anunciados.don´t forget to open a new topic if you have anything to say about this new firmware.pay attention that some sofcams can make some autorrols to stop working.big9 firm especial para os amigos do jardim digital que se fartam de trabalhar.
RNC®
RNC®
Member of Light
AMD Athlon64 3200+//
HE*D SD 790 FTA
Vila Real, Portugal
Firmware V0194 - 31/03/2008
SD790
_http://www.sendspace.com/file/qq0lzn
SD2500
_http://www.sendspace.com/file/s27dqy
SD3900
_http://www.sendspace.com/file/pdjko7
SD7200
_http://www.sendspace.com/file/j183f4
RNC®
RNC®
Member of Light
HE*D SD 790 FTA
Vila Real, Portugal
Firmware V0197 - 15/04/2008
for (Multi ... Free x. au..polsat .au.....premiere au, tps au, other...).
SD790 Testado ok
_http://www.sendspace.com/file/2rylpt
SD2500
_http://www.sendspace.com/file/au8khq
SD3900
_http://www.sendspace.com/file/n1mmho
SD7200
_http://www.sendspace.com/file/uj5v79
Cumps
makrolon
makrolon
metronic k-box single441320/he@d2000/he@d790sd/prato120cmhotbird7prato80cmhispasat7pc windows xp sp2
portugal
[:-handclapbravo RNC, o meu sd790 está com este firm(197)hà 2 semanas e,nunca tive o meu deco a trabalhar tão bem!!!é excelente!!!já nem as ke*s pol*at q abrem nag*avision eu tenho q me preocupar em procurar a softcam para pôr com o loader!muito bom mesmo!obrigado RNC
big9
big9
clã dos mouros
Firmware V200 - 29/05/2008
for TPS AU,PREMIERE AU,POLSAT AU*Other enjoy*globo ok with the latest keys,orf ok
PASS:head77
a very special thanks to BIG10 aka RAFA
SD790-TESTED OK
_http://www.sendspace.com/file/bk4qtg
SD2500
_http://www.sendspace.com/file/n7be20
SD3900
_http://www.sendspace.com/file/sl58ji
SD7200
_http://www.sendspace.com/file/bphllj
Para info e comentários e perguntas á cerca do firm abram um outro topico na secção geral pf.Atenção alguns keycodes(softcams)podem anular os autorrols anunciados.don´t forget to open a new topic if you have anything to say about this new firmware.pay attention that some sofcams can make some autorrols to stop working.big9 firm especial para os amigos do jardim digital que se fartam de trabalhar(lol).
Poison
Poison
He@d 500
بلدي اميرة القلب
Firmware para o He@d serie SDxxxx Black Panther
Firmware V311 - 29/05/2008
PASS:head77
SD790 BP
_http://www.mediafire.com/?7vzxj29vzxx
SD2700 BP
_http://www.mediafire.com/?jejm5vxgtzk
SD7200 BP
_http://www.mediafire.com/?0badx11hj1m
Thank's and a special Hug to Big10 ;)
