Iranian streams plus French satellite with octagon sf8008 - advice requested
eli_88
None
SW UK
Hi, I want to find a way to have Iranian domestic channels and also French satellite channels on my TV. At the moment I watch the Iranian ones on my laptop (legally) and I used to have a dish for French TV. I believe the domestic Iranian channels can not be received by sat in the UK (they are on Badr 5). Yes, some of them are on 13E again but unfortunately not the most common domestic channels that I need (IRIB 1,2,3 4 etc.).
Would this receiver work for me to combine the French satellite channels and also the domestic Iranian streams in one receiver? And would the Iranian streams be recordable?
I was thinking of a big dish for the French multistreams on 5W with Iranian IPTV.
Thanks for any help.
LeBelge
2x Triax TD 110, 2x Edision OS Mio 4K (plus), Edision OS Mini 4K, Edision OS Nino Pro
Belguim
Octagon SF8008 or Edision OS Mio 4k will both work for the French satellite channels from 5°W.
I use a Triax TD 110 dish for multistream.
eli_88
None
SW UK
Thanks. I have a 90 cm dish but sounds like that might not be good enough. :(
Does it also handle internet streams?
Edit: I want to point out that the IRIB streams are legal, they are available on their website and worldwide with just blocking when some films and sport (usually football) is on.
LeBelge
Belguim
The 90 cm dish will not do the job in winter because the FEC is 8/9.
There is an easier way to get the French stuff.
Either get a Fransat receiver / CAM and put up a small dish for 5W or spend €60/year and get a BIS sub and CAM with a dish aimed at Hotbird.
Stevenvc19
3x Edision Primo S2:
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
I can confirm, for Belgium, a 90cm dish will do the job perfectly. (for receiving the French Multistream channels at 5W)
Only in case of heavy rain or lightning the channels will fade away. But it happens maybe 2 times a year and that for 5 - 10 minutes max.
For the UK a Triax 110 will of course be better but you can try with your 90 cm dish to start with and see how it goes.
LeBelge
Belguim
For technical and security reasons of access rights, the Fransat PC6 card has a lifespan limited to 4 years, starting from the date of its first insertion into the decoder or TV module.
After 4 years he will need a friend living in France to order on line a new Fransat PC6 card (15€), but! with french credit card and address in France for the shipping.
Of course, everyone has the right to help increase the profits of wealthy french capitalists, but pay tv subscriptions are not my cup of tea. Me, I have studied marketing and I do not allow multimillionaires to cheat me. They are rich enough without stealing my money.
No need for a french address etc - the cards are eadily & cheaply available pre activated online.
eli_88
None
SW UK
My reason for going for the multistreams is to be able to record.
I've had French satellite TV before, my main issue at the moment is the Iranian domestic channels.
Adam792
Cheltenham
I use an 80cm dish for the 8PSK 8/9 French multistreams and the signal is absolutely fine all year, further north in central England. The only times it ever drops out is in the heaviest rain, and rain heavy enough to do that is not very common at all.
italy2006
starsat
iran
IRIB package on intelsat 39 have good coverage over Europe.It seems that signal can be received there.
eli_88
None
SW UK
Yes, thanks for that information. I had realised that yesterday, and it was the last thing I expected. I am going to be trying it out but the issue is that apparently you need a clear view to the horizon (I asked in another thread). I do have that, I live in a house that faces due south and there is a field in front, but there is a very slight incline in the land and some houses half a mile away which I understand might be enough to block the signal.
LeBelge
Belguim
Is it never snowing in England?
For someone who speaks English it is better to also watch tv channels from 4.8°E & 0.8°W, isn't it?
v
