Need instructions how to install cccam on my db500 Thank you
K karibu Member Joined Oct 14, 2009 Messages 34 Reaction score 0 Points 0 Age 54 My Satellite Setup Dreambox My Location Greece Dec 21, 2011 #1 Need instructions how to install cccam on my db500 Thank you
Lazarus Retired Moderator Joined May 29, 2009 Messages 27,119 Reaction score 8,697 Points 113 My Satellite Setup 80cm Motorised. Several small Dishes. Much else. My Location North York Moors Dec 21, 2011 #2 All the info is here already. Try looking at Threads here Dreambox Guides, Stickies and FAQs and/or use the forum Search facility. We don't keep re-inventing the wheel, but once you've found the info and digested it, any remaining specific issues can be dealt with.
K karibu Member Joined Oct 14, 2009 Messages 34 Reaction score 0 Points 0 Age 54 My Satellite Setup Dreambox My Location Greece Dec 21, 2011 #3 thank you I just need instructions how to install it manually nothing else
Analoguesat Administrator Staff member Joined Jul 26, 2003 Messages 51,046 Reaction score 11,502 Points 113 Location Scottish Borders My Satellite Setup TM 5402HD Sky+ UK. My Location Scottish Borders Dec 21, 2011 #4 Its normally something along the lines of unzip (if required) ftp the cam package onto /tmp then do a manual install via the menu structure.
K karibu Member Joined Oct 14, 2009 Messages 34 Reaction score 0 Points 0 Age 54 My Satellite Setup Dreambox My Location Greece Dec 21, 2011 #5 menu strucrure you mean bleu panel?
Analoguesat Administrator Staff member Joined Jul 26, 2003 Messages 51,046 Reaction score 11,502 Points 113 Location Scottish Borders My Satellite Setup TM 5402HD Sky+ UK. My Location Scottish Borders Dec 21, 2011 #6 I dont know the exact menu structure for a 500 as Ive never used one, but somewhere there will be the option to manually install add ons.
K karibu Member Joined Oct 14, 2009 Messages 34 Reaction score 0 Points 0 Age 54 My Satellite Setup Dreambox My Location Greece Dec 21, 2011 #7 ok there are some other files into tmp. what should i do with them? should i keep them and add the new ones?
