NEU: OCTAGON SX89 / SX89 WL HD H.265 S2+IP und SX889 / SX889 WL HD H.265 IP
http://www.octagon-germany.eu/
OCTAGON SX89 HD H.265 S2+IP
Zum Produkt
OCTAGON SX89 WL HD H.265 S2+IP
Zum Produkt:
OCTAGON SX889 HD H.265 IP
Zum Produkt
OCTAGON SX889 WL HD H.265 IP
Zum Produkt
Manikm909
Small'ish Dish Man
Kent, UK
so we now have an SX87 SX88 SX89 - am i the only one thats confused...how is one better than the other.
That would depend upon what factors combine, for you, to fulfil your definition of "better".
Firmware (Software) Update V10544 11-03-2021
OCTAGON:
SX89
SX89 WL
SX889
SX889 WL
Changes:
1. Fixed some channel A/V no sync.
2. Add. Reload function for Stalker in TV list.
3. Update Driver RTL88x2BU.
4. Hotkey fixed.
5. Add. smod.
6. Info Button Select the groups to hide in Stalker.
E2TV Nutzung auf OCTAGON SX Modellen:
a.) Installieren Sie die aktuelle Firmware v10544.
b.) Starten Sie das Plugin E2TV.
c.) IP Adresse Ihres Enigma2 Receivers eingeben und speichern (verbinden).
E2TV use on OCTAGON SX models:
a.) Install the latest firmware v10544.
b.) Start the E2TV plugin.
c.) Enter the IP address of your Enigma2 receiver and save (connect).
OCTAGON SX modellerinde E2TV kullanımı:
a.) En son yazılımı v10544'i yükleyin.
b.) E2TV eklentisini başlatın.
c.) Enigma2 alıcınızın IP adresini girin ve kaydedin (bağlayın).
SX89 & SX89 WL:
SX889 & SX889 WL:
Online Update verfügbar!
Online Update ready!
Online güncelleyin!
OCTAGON GERMANY SUPPORT
Firmware (Software) Update V10546 28-03-2021
OCTAGON:
SX89
SX89 WL
SX889
SX889 WL
Changes:
1. Fixed some Portal Protocol.
a.) Installieren Sie die aktuelle Firmware v10546.
a.) Install the latest firmware v10546.
a.) En son yazılımı v10546'i yükleyin.
SX89 & SX89 WL:
SX889 & SX889 WL:
Online güncelleyin!
Firmware (Software) Update V10547 02-04-2021
OCTAGON:
SX89
SX89 WL
SX889
SX889 WL
Changes:
1. Fixed Subtitle ASS - Advanced Sub Station.
2. Some minor issues Fixed.
a.) Installieren Sie die aktuelle Firmware v10547.
a.) Install the latest firmware v10547.
a.) En son yazılımı v10547'i yükleyin.
SX89 & SX89 WL:
SX889 & SX889 WL:
Online güncelleyin!
Firmware (Software) Update V10548 18-04-2021
OCTAGON:
SX89
SX89 WL
SX889
SX889 WL
Changes:
1. Sat-Finder eingebaut. 2xInfo Taste - Option Taste.
2. Stalker Multi MAC Nutzung eingebaut. (Stalker - Option - System)
3. Stalker Radio Hintergrund Bild eingebaut.
4. MAC Änderung über WEBIF eingebaut.
1. Sat-Finder added. 2xInfo Button , Option Button.
2. Multi MAC ID Support added. (Stalker - Option - System)
3. Stalker Radio Background picture added.
4. MAC ID Edit (change) over WEBIF added.
a.) Installieren Sie die aktuelle Firmware v10548.
a.) Install the latest firmware v10548.
a.) En son yazılımı v10548'i yükleyin.
SX89 & SX89 WL:
SX889 & SX889 WL:
Online güncelleyin!
Firmware (Software) Update V10550 16-05-2021
OCTAGON:
SX89
SX89 WL
SX889
SX889 WL
Changes:
1. Satellit 27.5W Programmsuchlauf Funktion eingebaut.
2. Youtube Kids und TRT Cocuk app`s ins Hauptmenü eingebaut.
3. Multi-Mac Funktion verbessert.
4. Favoriten und Nicht zu ende Funktionen ins Stalker Vod eingebaut.
1. Added 27.5W Satellite Channel Scan - Search.
2. YouTube Kids and TRT Cocuk app`s added in Main Menu.
3. Fixed Multi-Mac function issue.
4. Added Favorites and Not Ended function to Stalker Vod.
a.) Installieren Sie die aktuelle Firmware v10550.
a.) Install the latest firmware v10550.
a.) En son yazılımı v10550'i yükleyin.
SX89 & SX89 WL:
SX889 & SX889 WL:
Online güncelleyin!
FWIW, my really old SX88 might finally have now "met its maker", thus an Sx89 might "make sense" and so:
- what are members' experiences with the Sx89 over the last few months?
- is there anywhere in the UK from where I could buy one "with confidence"?
- if not an SX89, then what Rx with relatively similar (or "better") performance and "useability" might be suggested?
Thx in advance.
PS: nothing Linux-based!
rodscha
how easy is it to use this Octagon when you had a Comag before?i.e. no knowledge of Linux systems?
does it need to be programmed,or do you just organise favorite lists as you would on a Comag ?
Who are you asking because I never had a Comag?!!!
(PS: now found out that my SX88 is actually OK - the problem was at the dish down the garden!)
Thx in advance.
Don't think I've seen anyone on here mention they have an SX89, not unsurprising given they have no obvious advantage over an SX88+.
@rodscha they're as simple as 'hobby' receivers get :)
Well, according to the SX89 spec, it has a much faster processor (which could help as the SX88/88+can be decidedly sluggish to do "compllicated things" at times), other internal improvements, USB3 port and the later and reportedly "better" design of R/C.
Would seem to have been a good replacement for the SX88 if that had actually failed, but my interest in the SX89 has now wained because it hasn't.
OTOH. as you say, the uptake of the SX89 (at least in the UK) appears to have been decidedly slow, and they only seem to be available from German suppliers - so probably only bought by people who have (a) not already got a working SX88 & (b) actually know that the SX89 exists!
No USB 3 on the SX87 or 89, which put me off completely. May as well get an SF8008 and run Define on it, or a much cheaper SX88+.
Firmware (Software) Update V10568 & V10571 14-11-2021
OCTAGON:
SX87, SX87 WL
SX887, SX887 WL
SX89, SX89 WL
SX889, SX889 WL
Changes:
1. Xtream M3u und Stalker verbessert.
2. DVB-S2 Tuner CH. Zap Geschwindigkeit verbessert.
3. Internet CH. Zap Geschwindigkeit verbessert.
4. Picons aktualisiert wie Astra19 Hotbird13 Türksat42.
1. Xtream M3u and Stalker improved.
2. DVB-S2 Tuner CH. Zap speed improved.
3. Internet CH. Zap speed improved.
4. Picons upgrade like Astra19 Hotbird13 Türksat42.
1. Xtream M3u ve Stalker uygulamalari iyilestirildi.
2. DVB-S2 Tuner Kanal gecis hizi artirildi.
3. Internet IPTV Kanal gecis hizi artirildi.
4. Astra19 Hotbird13 ve Türksat42 Picon`lar güncellendi.
a.) Installieren Sie die aktuelle Firmware v10569.
a.) Install the latest firmware v10569.
a.) En son yazılımı v10569'i yükleyin.
SX87 & SX87 WL
SX887 & SX887 WL
SX89 & SX89 WL
SX889 & SX889 WL
Online güncelleyin!
Firmware (Software) Update V10570 & V10573 19-12-2021
OCTAGON:
SX87, SX87 WL
SX887, SX887 WL
SX89, SX89 WL
SX889, SX889 WL
Changes:
1. OCTAGON SF8008 Fernbedienungscode eingebaut.
2. Sendersuchlauf für 4.8E und 1W Thor verbessert.
3. TimeShift für Stalker verbessert.
4. UserAgent fix.
5. HDMI Ausgang fix.
6. Video Treiber aktualisiert.
1. OCTAGON SF8008 Remote Control (RCU) added.
2. Channel Scan for 4.8E and 1W Thor improved.
3. TimeShift archive for Stalker improved.
4. UserAgent fix.
5. HDMI out fix.
6. Video driver upgrade.
1. OCTAGON SF8008 uzaktan Kumanda destegi eklendi.
2. 4.8E ve 1W Thor uydulari kanal arama özelligi iyilestirildi.
3. Stalker TimeShift arsiv özelligi iyilestirildi.
4. UserAgent özelligi iyilestirildi.
5. HDMI cikis hatasi giderildi.
6. Video sürüm güncellendi.
a.) Installieren Sie die aktuelle Firmware v10xxx.
a.) Install the latest firmware v10xxx.
a.) En son yazılımı v10xxx'i yükleyin.
SX87 & SX87 WL
SX887 & SX887 WL
SX89 & SX89 WL
SX889 & SX889 WL
Online güncelleyin!
