danzig
- Feb 28, 2005
- Age
- 40
Hello everyone..
i have a problem upgrading my nokia mm 9200 . fta1.0 . b2.00uns .
i tryed using the nokia tool (serial download) and transbox.
with the nokia tool i do everthing it's telling me to do and then i see somthing like "waiting for reciver" and nothing happens. also with the transbox i have the same problem( waiting for device or somthing like that) i chacked the rs232 cable (looked if there is a transfer with a little lamp and a baterry and saw that it has the same pin-order diagram as the manual) what could be the problem? is somthing blocking my reciver? why he is not responding to the computer? is there any program that can chack the transfer between the com port and the reciver? can i upload the software on another way?
Thank You very much.
